How to Xport coord to excel (suite)
I am quite new to VBA. Concerning the code to export that you showed:
What is the instruction/code line to add to it so that it continue to wait for user input until an event (like pushing ESC, right clicking, typing any key) occurs?
Thanks again
There are lots of sample code items for this in the help files.
Laurie Comerford
www.cadapps.com.au
wrote in message news:5231137@discussion.autodesk.com...
key) occurs?
Thanks again
This will export text to excel from a aleady open excel session.
hope this helps
John Coon
Option Explicit
Public intRow As Integer
Public strCell As String
' Application - Excel
Public oExcel As Excel.Application
Public oBook As Excel.Workbook
Public oSheet As Excel.Worksheet
Private Sub CreateExcel()
Dim i As Integer
Set oExcel = CreateObject("Excel.Application")
Set oBook = oExcel.Workbooks.Add
Set oSheet = oBook.Worksheets(1)
oExcel.Visible = True
End Sub
Public Sub TextToExcel()
Dim obj As AcadEntity
Dim objText As AcadText
Dim varInsert As Variant
' Create an Excel object
CreateExcel
oExcel.Cells(1, 1).Value = "X: COORDINATE"
oExcel.Cells(1, 2).Value = "Y: COORDINATE"
oExcel.Cells(1, 3).Value = "TEXT"
intRow = 2
For Each obj In ThisDrawing.ModelSpace
If TypeOf obj Is AcadText Then
Set objText = obj
oExcel.Cells(intRow, 3).Value = objText.TextString
varInsert = objText.InsertionPoint
oExcel.Cells(intRow, 1).Value = varInsert(0)
oExcel.Cells(intRow, 2).Value = varInsert(1)
intRow = intRow + 1
End If
Next obj
End Sub
key) occurs?
Thanks again
