How to run a function when dvb file is embeded
m09366023695
m09366023695
hi
I run this command and it works fine:
(command "vbarun" "F:/gr/masoud.dvb!ThisDrawing.main")
now I embeded masoud.dvb file with VBA Manager.(attached file).
Now I want to create a icon with CUI command.
I should use path again?
paullimapa
You may get better feedback by posting here
https://forums.autodesk.com/t5/vba/bd-p/33
Paul Li
IT Specialist
@The Office
cadffm
??  Make no sense
The path is to load the dvb file only,
your embedded function is in your dwg, no longer in a dvb file
and embeddeds are always loaded (if allowed).
Skip the path an separator(!)
Sebastian
Ed__Jobe
Hi @m09366023695
I don't recommend embedding the dvb if you plan to use a cuix file with it. The cuix will always require that you load the dwg that the code is embedded into. Keep it as a dvb. Then create an mnl file with the same name as your cuix. The mnl will automatically load when your cuix is loaded. Now, in the mnl, add lisp to load the dvb and a (defun) to create a command for your vba code. Now you can run your command by typing it at the command line or from your ribbon tab.
See my instructions for the mnl over at AUGI.com.
Ed
How to post your code.
