How to remove yellow color
Message 1 of 13
I just this code from "How to make a layout active,reply by R.Robert Bell,at
6/23/2004",and then tested it,but in VBA editor window ,display the yellow
color.
I really don't know how to remove it and what happened,would you inform to
me,to guide me on true way.
Thanks for your suggest and your help.
Sub Test()
ThisDrawing.ActiveLayout = ThisDrawing.Layouts.Item("Layout3")
End Sub
note; my layout only there are "layout1,layout2"
Replies (12)
Message 2 of 13
The yellow highlight is the debugger showing you where an error occurred.
Because the layout doesn't exist, that statement will cause an error.
The Debug toolbar has a Reset button on it, to stop the execution of the
code.
R. Robert Bell
"Adesu" wrote in message
news:[email protected]...
color.
Sub Test()
End Sub
Message 3 of 13
Hi Bell,thanks for your input info.
"R. Robert Bell" wrote in message
code.
R. Robert Bell
color.
Sub Test()
End Sub
Message 4 of 13
Hi Bell or others,
I just tested a code to create a line,like this below,and then as "mfauxock"
tutorial I follow it
Tools >select a file > run
after that display alert box and on "Drawline"display highlight with blue
color,and so it's said "Compile error: Expected Function or Variable",then
click Ok,at the code "Public Sub Drawline()" also display highlight yellow
color.
My question is how to revised this code?
[code]
Dim lineobj As AcadLine
Dim StartPoint(0 To 2) As Double
Dim EndPoint(0 To 2) As Double
'Define startpoint the line point
StartPoint(0) = 0: StartPoint(1) = 0: StartPoint(2) = 0
'Define endpoint the line point
EndPoint(0) = 10: EndPoint(1) = 10: EndPoint(2) = 0
'Create a line in model space
Set lineobj = ThisDrawing.ModelSpace.AddLine(StartPoint, EndPoint)
ThisDrawing.SaveAs Drawline.dwg
End Sub
[/code]
code.
R. Robert Bell
color.
Sub Test()
End Sub
Message 5 of 13
ThisDrawing.SaveAs "Drawline.dwg"
You must enclose strings in double quotes. By not doing so VBA thinks that
you are trying to get the .dwg property or method of the Drawline function
which doesn't exist.
[code]
End Sub
[/code]
code.
R. Robert Bell
color.
Sub Test()
End Sub
Message 6 of 13
Hi Jeff,it's great worked,thanks.
And how if we want to execute in command prompt,is'it possible?
as like Autolisp , only just type "what your have code" and then hit enter.
"Jeff Mishler" wrote in message
[code]
End Sub
[/code]
code.
R. Robert Bell
color.
Sub Test()
End Sub
Message 7 of 13
I think, you can creat button and use macro, assign value button is funtion.
Maybe that is another way use.
Message 8 of 13
Hi chubby667,
No, I 'm will not creating a button to execute a VB,it's too far solution
for me,I'm still beginner,knowledge in VBA = 0.
wrote in message news:[email protected]...
Message 9 of 13
You can try:
^C^C_-vbarun;(name macro)
Message 10 of 13
Do you mean like this
Command: (^C^C_-vbarun; "Add Point.dvd")
It's got trouble !!
You can try:
Message 11 of 13
No, it is funtion of button.
If from commandline:
command:-vbarun
command:macro
Try it:
Message 12 of 13
Ya.. it's ok,but very different with autolisp.
thanks.
command:-vbarun
command:macro
Try it:
Message 13 of 13
No problem.
See you.
Chubby
