How to quick select all entity have same property
tim11_manhhieu
tim11_manhhieu
The execution sequence will be like this
1) select the object
2) run the macro
3) all objects in drawing with the same properties as the object in step 1) will be selected.
Does anyone have the vba or lisp code that can share with me?
Brock_Olly
You want a LISP i'm guessing?
This also depends on which properties you want to be the same.
This chatgpt-lisp selects based on Layer, Colour and Object type
Doesn't seem to work for dynamic blocks though.
You could also just use Selectsimilar command and tweak it with SELECTSIMILARMODE
(defun c:SSAME ( / ent entData objType objLayer objColor blockName filter ss)
  ;; Step 1: Select an object
  (setq ent (car (entsel "\nSelect object with desired properties: ")))
  (if ent
    (progn
      (setq entData  (entget ent))
      (setq objType  (cdr (assoc 0 entData))) ; Object type
      (setq objLayer (cdr (assoc 8 entData))) ; Layer name
      (setq objColor (cdr (assoc 62 entData))) ; ACI color
      ;; If it's a block reference, get the block name
      (if (equal objType "INSERT")
        (setq blockName (cdr (assoc 2 entData)))
      ;; Step 2: Build filter list
      (setq filter (list (cons 0 objType)
                         (cons 8 objLayer)))
      (if objColor
        (setq filter (append filter (list (cons 62 objColor))))
      (if blockName
        (setq filter (append filter (list (cons 2 blockName))))
      ;; Step 3: Select matching objects
      (setq ss (ssget "X" filter))
      ;; Step 4: Feedback
      (if ss
        (progn
          (prompt (strcat "\nFound " (itoa (sslength ss)) " matching object(s)."))
          (sssetfirst nil ss)
        (prompt "\nNo matching objects found.")
    (prompt "\nNothing selected.")
  (princ)
Ed__Jobe
Have you tried the QSELECT command? You can type it in or access it from the Properties palette.
Ed
How to post your code.
tim11_manhhieu
That is amazing, I didn't know there was a SELECTSIMILAR command. Appreciate.
tim11_manhhieu
If using Qselect, it quite time consuming because I have to select object, property, value.
Brock_Olly
Just for your information, selectsimilar can be called form the right-click-menu.
tim11_manhhieu
Sorry for my poor AutoCad, thank you again.
