How to list all module and sub routine in ACADProject
tim11_manhhieu
tim11_manhhieu
My idea is to create a userform, and display sub routine and modules on it.
I want to run a sub routine in module by clicking on it.
I just need to know how to list them. I can create userform.
Because I have many modules, calling the toolbar is not very good.
Ed__Jobe
I would recommend against this method. You should learn to use the AutoCAD interface, specifically the CUI and ribbon. At AUGI I have a post that describes a good way to organize your code to make it easier to use your VBA in the ribbon. You can also use tool palettes if you don’t like the ribbon.
But if you must create your own user interface, you can query loaded projects by using the VBE api. You must reference “Microsoft Visual Basic for Applications Extensibility 5.3”.
Ed
How to post your code.
tim11_manhhieu
thank you for detailed response.
