How to know in wich space is a selected object ?
TONELLAL
TONELLAL
All is in the title...
I have to select blocks, then replace them by other blocks.
I select them by :
FilterType(0) = 0
FilterData(0) = "Insert"
oSS.SelectOnScreen FilterType, FilterData
This is ok, I select only Block entities.
Then I replace blocks :
oBlock.delete
Set BlockRefObj = ThisDrawing.ModelSpace.InsertBlock(insertionpoint, blockname, 1#, 1#, 1#, rotateAngle)
...but this always insert the block in ModelSpace.
How can I detect in wich space is the original block, so I can insert the new blocx using Modelspace or Papersace (i) ?
Norman_Yuan
You can use AcadDocument.ActiveSpace to test what the current space the selection is performed, because you do selecting on screen, which only allows you select entities in current/active space (either model, or paper)
So, you can do something like:
If ThisDrawing.ActiveSpace=AcModelSpace Then
  Set BlockRefObj=ThisDrawing.ModelSpace.Insert(....)
Else
  Set BlockRefObj=ThisDrawing.PaperSpace.Insert(....)
End If
Norman Yuan
Drive CAD With Code
TONELLAL
"... because you do selecting on screen, which only allows you select entities in current/active space " :
This is exactly where my problem is : if you select All, you select in paperspace AND in modelspace...
Alfred.NESWADBA
each entity has an OwnerID which points to the block which holds the object, that can be the blockdefinition called modelspace, it can also be the blockdefinition of every layout existing in the drawing.
Let's see if that helps (code goes through "Point" objects in a selection set and places a new blockreference at the position of the point (and in the modelspace or layout(s) of that point(s).
Dim tEnt As AcadPoint
For Each tEnt In tSelSet
   Debug.Print ("")
   Dim tBlock As AcadBlock
   Set tBlock = ThisDrawing.ObjectIdToObject(tEnt.OwnerID)  'that is the owner (parent) of the point
   Dim tBlRef As AcadBlockReference
   Set tBlRef = tBlock.InsertBlock(tEnt.Coordinates, "NewBlockName", 1, 1, 1, 0)
Next
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
TONELLAL
Thanks Alfred !
I did something like this :
Space = ThisDrawing.ObjectIdToObject(tEnt.OwnerID)
If Space.Name = "*Paper_Space" Then
    Set BlockRefObj = ThisDrawing.PaperSpace.InsertBlock(insertionpoint, blockname, 1#, 1#, 1#, rotateAngle)
Else
End If
Alain
Alfred.NESWADBA
>> I did something like this [...]
Sorry, that might fail. If you have more than one layouts then the "ThisDrawing.Paperspace" points to the first/active layout,
In case your blockreference is on layout3 your insertion would be done on layout1 instead of layout3
That's why I suggested do use (using your variables) Space.InsertBlock....
- alfred -
Alfred NESWADBA
TONELLAL
Ok, not understood very well first time.
I noticed the problem if I have several layouts, but strangely it seems to function...
