How to Iterate through every line of a selectionSet?
Message 1 of 1
I want to create a selection set for lines if their startPoint or EndPoint is at some Location,
The Code from Below only returns the value that I want from 1 line Only, it omits the others.
I want to output the endpoint and startpoint of every line (4 lines in this case)
I am new to VBA and AutoCAD it looks like I have to create an Array containing all the things selected by the selectionset
These are the Lines that I need to iterate trough:
I looks like it only selects one:
Sub test()
    Dim j As Integer
    Dim x As Object
    Dim startPoint As Variant
    Dim endPoint As Variant
    Dim a As AcadSelectionSet
    Set a = ThisDrawing.SelectionSets.Add("MySelectionSet")
    Dim point(0 To 2) As Double
    point(0) = 0: point(1) = 0: point(2) = 0
    a.SelectAtPoint point
    MsgBox ("Selection set " & a.Name & " contains " & _
    a.Count & " items")
    j = 0
    For Each x In a
       MsgBox "Item " & CStr(j + 1) & " in " & a.Name _
         & "is: " & x.EntityName
         startPoint = x.startPoint
         endPoint = x.endPoint
        MsgBox "this is " & startPoint(0) & " " & startPoint(1) & " " & startPoint(1) & "  " & endPoint(0) & "  " & endPoint(1) & " " & endPoint(2)
       j = j + 1
    Next
     ' Delete selectionset
       ThisDrawing.SelectionSets.Item("MySelectionSet").Delete
End Sub
I am confused with entities, Can we say that there are 4 entities in this selection set of type line?
Why is not selecting all and if it is why is the iteration only returning the value of one?
Thank You,
Replies (0)
