How to get value from Excel to Autocad?
Hi!
I need to export a large number of DWG files to version 2000. I would like to take the path from Excel and then run the rest of the rule. Can anyone have an idea how to solve it?
This is rule
Option Explicit
Sub Ch3_TestIfSaved()
Dim app As AcadApplication
Set app = ThisDrawing.Application
Dim Pan As Integer
Pan = InputBox("Ile wierszy?", "tak")
Dim i As Integer
i = 1
Do
Set dwg = app.Documents.Open("D:\Obszary Robocze\Instalacje Modułowe\Designs\Rysunek1.dwg")
Call app.ActiveDocument.SaveAs("D:\Obszary Robocze\Instalacje Modułowe\Designs\Rysunek1_2000.dwg", ac2000_dwg)
dwg.Close
i = i + 1
Loop Until i > PanNum
End Sub
Ed__Jobe
For something this simple, I would just use ScriptPro, which can be downloaded from GitHub here: https://github.com/ADN-DevTech/ScriptPro-installer
Just create a *.scr and then create a new ScriptPro project, select the scr to run and then select the files to convert.
Ed
How to post your code.
Thank you for your answer. However, I chose the method in which it points to the path to the folder, and each .dwg file in the folder is then subject to the operation of writing to the version 2000.
