how to get the position coordinates of a dynamic block
victorctti
victorctti
Hello, I'm developing code in VBA that takes information from a block and fills a table and I'm not able to get the x y z coordinates, if anyone could help I would be very grateful and thank you very much for your attention. attached code
Public NumNCE As Single
Public TagBl As String
Public NumNDT As String
Public NumNDC As String
Public props() As AcadDynamicBlockReferenceProperty
'Public CordXYZ As AcadBlockReference
'Public InsertionPoint() As Double
'Public CodXYZ As Double
Sub CONT_BOX_ESGOTO_COM_TAB()
Dim FilterData(0 To 1) As Variant 'cria a variavel filtro data
Dim FilterType(0 To 1) As Integer 'cria a variavel filtro type
Dim FlagTCdAnt As Boolean
Dim ModelSpecObj As AcadModelSpace
Dim NCirc As Integer
Dim NCol As Integer, NLin As Integer
Dim NOrig As Integer
Dim NumLinsTCd As Variant
Dim PtoInsTCd As Variant
Dim PtoLL As Variant, PtoUR As Variant
Dim PtoMR(0 To 2) As Double
Dim TabEnt As AcadTable
Dim TCCdEnt As AcadTable
Dim Verde As AcadAcCmColor
Dim Dad() As String
Dim TagShf As String
Dim LrgShf As Single
Dim PrfShf As Single
Dim dados As String
'Dim InsertedBlock As AcadBlockReference
'Dim IP(0 To 2) As Double
'Dim props() As AcadDynamicBlockReferenceProperty
'Dim Cod As Double
Key = 0
col = 8
LrgShf = 1
PrfShf = 1
'lin = NumNCE + 2
FlagOsnap = ThisDrawing.ObjectSnapMode
If FlagOsnap Then
    ThisDrawing.ObjectSnapMode = True
'MENSAGEM DO inputbox
NumNCE = InputBox("Entre o numero inicial para numeração de caixas de esgoto", "Numero de caixas de esgoto")
TagBl = InputBox("Defina o código inicial da tag (3 caracteres)", "Tag do bloco")
For Each SSet In ThisDrawing.SelectionSets
    If SSet.Name = "CDI" Then
        ThisDrawing.SelectionSets.Item("CDI").Delete ' elemina outro selection set chamado cdi
        Exit For
Next SSet
Set SelCDI = ThisDrawing.SelectionSets.Add("CDI") 'seta um selection set chamado cdi
Set BlkCol = ThisDrawing.Blocks ' setar o bloco a ser modificado
FilterType(0) = 0
FilterData(0) = "Insert" 'tudo que é inserido
FilterType(1) = 8 ' vai precisar acrescentar desenhos 3d
FilterData(1) = "AHD" ' preciso trocar o shf
FimSel = 1 ' chave para entrar no while
Do While FimSel <> 0
    SelCDI.SelectOnScreen FilterType, FilterData ' cria o selection set chamado cdi com um filtro de busca 0,
    'inserido, bloco dinamico, layer AHD
    If SelCDI.Count = 1 Then ' se tiver uma seleção entra no if
        Set BlkEnt = SelCDI(0) ' se a caixa de esgoto estiver no selection set
        AtribCol = BlkEnt.GetAttributes 'pega o atributo da caixa de esgoto
      '  Insert = BlkEnt.GetBlockProperties()
'        Cood = BlkEnt.Coordinates
        'props = BlkEnt.GetDynamicBlockProperties
        NumAtribs = UBoundAtributes 'define o valor do atributo
        NumAtribs = UBound(AtribCol) + 1 ' acrescenta o valor ao atributo da caixa de esgoto
        AtribCol(0).TextString = TagBl & NumNCE ' re-escreve o valor do atributo
        NumNDT = AtribCol(1).TextString
        NumNDC = AtribCol(2).TextString
        'CodX = Cood.Coordinates(0).TextString
        'CodY = Cood.InsertionPoint(1)
        'NumNDT = InputBox("Identifique o nivel da tampa", "Nivel da tampa")
        'AtribCol(1).TextString = NumNDT
        'NumNDC = InputBox("Identifique o nivel do fundo", "Nivel do fundo")
        'AtribCol(2).TextString = NumNDC
        Application.Update ' atualiza o desenho
        NumNCE = NumNCE + 1
        SelCDI.Clear ' limpa o selection set
        NumCarTagShf = Len(BlkEnt.Name)
        TagShf = Right(BlkEnt.Name, NumCarTagShf) ' - 3)
        Set BlkDef = BlkCol.Item(BlkEnt.Name)
        NumEntsShf = BlkDef.Count
        PtInsShf = BlkEnt.InsertionPoint
        AngTab = BlkEnt.Rotation
        XSFac = BlkEnt.XScaleFactor
        AtribColShf = BlkEnt.GetAttributes
         For NEnt = 0 To NumEntsShf - 1
            Set EntBlkCol = BlkDef.Item(NEnt)
            If EntBlkCol.ObjectName = "AcDbBlockReference" Then
                If Left(EntBlkCol.Name, 6) = "HD§COL" Then
                    NumColShf = NumColShf + 1
                    AtribColCol = EntBlkCol.GetAttributes
                    For Each AtribCol In AtribColCol
                        Select Case AtribCol.TagString
                        Case "TAG"
                            Dad(NumColShf, 1) = AtribCol.TextString
                        Case "DIA"
                            Dad(NumColShf, 2) = AtribCol.TextString
                        End Select
                    Next AtribCol
        Next NEnt
        HTab = (NumColsShf * 4 + 5) * Esc ' preciso redimencionar tudo isso para o meu objetivo
        DistP1 = Sqr((LrgShf / 2) ^ 2 + PrfShf ^ 2)
        AngP1 = Atn(PrfShf / LrgShf * 2)
        XInsTab = LrgShf / 2 - HTab / 2
        YInsTab = PrfShf * SFac + 10 * Esc
        DistPtTab = Sqr(XInsTab ^ 2 + YInsTab ^ 2)
        AngPtTab = Atn(YInsTab / XInsTab) + Pi
       PtTab = ThisDrawing.Utility.PolarPoint(PtInsShf, AngPtTab + AngTab, DistPtTab)
        PtP1 = ThisDrawing.Utility.PolarPoint(PtInsShf, AngP1 + AngTab, DistP1)
        PtP2 = ThisDrawing.Utility.PolarPoint(PtTab, AngTab, HTab / 2)
        If XSFac = -1 Then
            CorAng = Pi
        Else
            CorAng = 0
        DesTCol PtTab, AngTab + CorAng + Pi / 2, Val(NumColShf), TagShf, Dad
        Set LineObj = ThisDrawing.ModelSpace.AddLine(PtP1, PtP2)
            LineObj.Layer = "AHD"
    'End If
    'Next BlkEnt
        'ThisDrawing.ModelSpace.AddTable(3, col + 1, 3, 4, 10)
    Else
        FimSel = 0 ' libera do while
Loop
'NumNCE +2 IGUAL NUMERO DE LINHAS
End Sub
Sub DesTCol(PtInsTC As Variant, AngTC, NumCols As Integer, TagShf, Dad() As String)
Dim TColsEnt As AcadTable
Dim DimeA As Single
Dim DimeB As Single
Dim AZI As Single
Dim Key As Single
DimeA = props(0).Value + props(2).Value
DimeB = props(4).Value + props(8).Value
AZI = props(10).Value
Set Verd = AcadApplication.GetInterfaceObject("AutoCAD.acCmColor.20") ' talvez trocar as cores
Set Cyan = AcadApplication.GetInterfaceObject("AutoCAD.acCmColor.20")
Verd.ColorIndex = acGreen
Cyan.ColorIndex = acCyan
Set TColsEnt = ThisDrawing.ModelSpace.AddTable(PtInsTC, 3, 8, 4, 10) 'o 8 é a posição das colunas, NumCols +1 são as linhas
With TColsEnt
.AllowManualHeights = True
'.SetColumnWidth 1, 8
'.SetColumnWidth 2, 8
.MergeCells 0, 0, 0, 0
.SetRowHeight 0, 3
.SetCellContentColor 0, 0, Verd
.SetCellTextHeight 0, 0, 2
.SetCellTextHeight 1, 0, 1
.SetCellTextHeight 1, 1, 1
.SetCellTextHeight 1, 2, 1
.SetCellTextHeight 1, 3, 1
.SetCellTextHeight 1, 4, 1
.SetCellTextHeight 1, 5, 1
.SetCellTextHeight 1, 6, 1
.SetCellTextHeight 1, 7, 1
.SetCellAlignment 0, 0, acMiddleCenter
.SetCellGridColor 0, 0, AcCellEdgeMask.acLeftMask, Cyan
.SetCellGridColor 0, 2, AcCellEdgeMask.acRightMask, Cyan
.SetCellGridColor 0, 0, AcCellEdgeMask.acBottomMask, Verd
.SetCellGridColor 0, 1, AcCellEdgeMask.acBottomMask, Verd
.SetCellGridColor 0, 2, AcCellEdgeMask.acBottomMask, Verd
.SetCellGridColor 0, 3, AcCellEdgeMask.acBottomMask, Verd
.SetCellGridColor 0, 4, AcCellEdgeMask.acBottomMask, Verd
.SetCellGridColor 0, 5, AcCellEdgeMask.acBottomMask, Verd
.SetCellGridColor 0, 6, AcCellEdgeMask.acBottomMask, Verd
.SetCellGridColor 0, 7, AcCellEdgeMask.acBottomMask, Verd
'For NLin = 1 To NumCols
    'For NCol = 0 To 2
'        .SetCellAlignment NLin, NCol, acMiddleCenter
'        .SetCellTextStyle NLin, NCol, "SIMPLEX"
   ' Next NCol
'Next NLin
.SetCellGridColor NumCols, 0, AcCellEdgeMask.acBottomMask, Cyan
.SetCellGridColor NumCols, 1, AcCellEdgeMask.acBottomMask, Cyan
.SetCellGridColor NumCols, 2, AcCellEdgeMask.acBottomMask, Cyan
.SetCellGridColor NumCols, 3, AcCellEdgeMask.acBottomMask, Cyan
.SetCellGridColor NumCols, 4, AcCellEdgeMask.acBottomMask, Cyan
.SetCellGridColor NumCols, 5, AcCellEdgeMask.acBottomMask, Cyan
.SetCellGridColor NumCols, 6, AcCellEdgeMask.acBottomMask, Cyan
.SetCellGridColor NumCols, 7, AcCellEdgeMask.acBottomMask, Cyan
 If Key = 0 Then
    Key = 1
    .SetText 0, 0, "TABELA DE DADOS - CAIXA DE ESGOTO" '& TagShf
    .SetText 1, 0, "CAIXA"
    .SetText 1, 1, "NIVEL TAMPA (m)"
    .SetText 1, 2, "NIVEL FUNDO (m)"
    .SetText 1, 3, "DIMENS A (m)"
    .SetText 1, 4, "DIMENS B (m)"
    .SetText 1, 5, "COORD X (m)"
    .SetText 1, 6, "COORD Y (m)"
    .SetText 1, 7, "AZIMUTE (graus)"
    .SetText 2, 0, TagBl & NumNCE - 1
    .SetText 2, 1, NumNDT
    .SetText 2, 2, NumNDC
    .SetText 2, 3, DimeA
    .SetText 2, 4, DimeB
    .SetText 2, 5, "COORD X (m)"
    .SetText 2, 6, "COORD Y (m)"
    .SetText 2, 7, AZI
Else
    .SetText 0, 0, TagBl & NumNCE
    .SetText 0, 1, NumNDT
    .SetText 0, 2, NumNDC
    .SetText 0, 3, DimeA
    .SetText 0, 4, DimeB
    .SetText 0, 5, "COORD X (m)"
    .SetText 0, 6, "COORD Y (m)"
    .SetText 0, 7, AZI
    '.SetText NLin, 0, Dad(NLin, 1) ' 'PRENCHE A COLUNA 1
    '.SetText NLin, 2, Dad(NLin, 2) ''PRENCHE A COLUNA 3
'Next NLin
'.StyleName = "TABCOLS"
'    .ScaleEntity PtInsTC, 1 * Esc
 '   .Rotate PtInsTC, AngTC
    .Layer = "AHD"
End With
End Sub
*Moderator Edit* Changed code language to VB
Ed__Jobe
You have all the pieces of information you need. The BlockReference.InsertionPoint property is a variant consisting of an array of 3 doubles. You already have the block ref as BlkEnt, then you get the insertion point as PtInsShf. Now you just need to access the elements of the array. 0 is the X value, 1 is the Y value and 2 is the Z value.
Dim X As Double
Dim Y As Double
Dim Z As Double
X = InsPtShf(0)
Y = InsPtShf(1)
Z = InsPtShf(2)
Ed
How to post your code.
Ed__Jobe
Here's a helper class to use when working with points.
Save this code as a class module in your project.
Option Explicit
Private m_point(0 To 2) As Variant
Private Sub Class_Initialize()
        m_point(0) = 0#
        m_point(1) = 0#
        m_point(2) = 0#
End Sub
Public Sub Assign(point3D As Variant)
    If UBound(point3D) > 2 Then
        Err.Raise 1, "Pnt3D.Initialize", "Array out of bounds"
    ElseIf UBound(point3D) < 2 Then
        Err.Raise 2, "Pnt3D.Initialize", "Not a 3D point"
    ElseIf UBound(point3D) = 2 Then
        m_point(0) = point3D(0)
        m_point(1) = point3D(1)
        m_point(2) = point3D(2)
End Sub
Public Property Get x() As Double
    x = m_point(0)
End Property
Public Property Let x(x As Double)
    m_point(0) = x
End Property
Public Property Get Y() As Double
    Y = m_point(1)
End Property
Public Property Let Y(Y As Double)
    m_point(1) = Y
End Property
Public Property Get Z() As Double
    Z = m_point(2)
End Property
Public Property Let Z(Z As Double)
    m_point(2) = Z
End Property
Public Function ToArray() As Variant
    ToArray = m_point
End Function
Public Function ToString() As String
    ToString = "X:" & m_point(0) & ", Y:" & m_point(1) & ", Z:" & m_point(2)
End Function
Here's a sample of how to use it.
Public Sub pointTest2()
    Dim pnt As New Pnt3D
    pnt.x = 1.1
    pnt.Y = 2.2
    pnt.Z = 0#
    Debug.Print pnt.ToString
    Dim arr(0 To 2) As Double
    arr(0) = 3.3
    arr(1) = 6.6
    arr(2) = 0#
    pnt.Assign arr
End Sub
'you can also do things like
pnt.Assign BlkRef.InsertionPoint
Ed
