How to find parent & Child Relation ship of Xrefs in a drawing
HI
I am trying to list out all Xrefs from all drawings in a folder; the problem I face is how to determine the nested xrefs in an xref in the current drawing so that I could have the listing with hirer key such as that in the Xref manager.
I have a code below that gives me the xref names and path but does not tell me if this is a parent or child xref.
For Each tempBlock In ThisDrawing.Blocks
If tempBlock.IsXRef Then
xrlist.AddItem
xrlist.List(colno, 1) = tempBlock.Name
xrlist.List(colno, 2) = tempBlock.Path
End If
Next
Could someone tell me how to find out the parent and child xrefs in a drawing?
In AutoCAD open the DesignCenter and click the Search button.
From the Look For drop-down list, choose Xrefs.
From the drop-down list, choose the original files location.
E.g. C:\Documents and Settings\YourUserName\Desktop\Current\101-Sheets.
In the Search for the Name text box, enter the name of the Xref. You can use wildcards; for example SI*.
If you're really ambitious, you can just put * to search for all the Xrefs on your computer or network.
Click Search Now.
You can take snapshots by hitting the Print Screen/SysRq key and pasting it in Windows Paint, save as *.BMP or JPG.
Also, take a look to the ffollowing tip in the event you want your Xrefs names and paths in your drawing: http://www.cadforum.cz/cadforum_en/qaID.asp?tip=2513
I hope this may help.
Ruben Melara
CAD Manager
JAVITS II Architecture, LLC
New York, NY
Go into the blocks, search for BlockReferences, if found these are nested. You could make a recursive method that does the same on every found nested BlockReference. Then find these Blockreferences in the block-table, that will give you it's path.
BTW keep track of which Block holds the nested Reference.
MakCADD
Sub Find_Nested_Xrefs()
Dim ParentXref As AcadBlock
Dim NestedXref As AcadBlockReference
Dim xREF As AcadExternalReference
For Each ParentXref In ThisDrawing.Blocks
If ParentXref.IsXRef Then
For Each OBJECT In ParentXref
If OBJECT.EntityName = "AcDbBlockReference" Then
Set NestedXref = OBJECT
If ThisDrawing.Blocks(NestedXref.Name).IsXRef Then
debug.print NestedXref.Name & "-> Nested -> " & ParentXref.Name & vbCr
End If
End If
Next
End If
Next
End Sub
