How to do " Union operation " for Box and Cylinder using VBA in EXCELL
I am trying to do constructive solid geometry (Boolean operation ) using VBA in EXCEL, say a box and cylinder and then do "Union" operation
I am able to create the Box and Cylinder. But I can't do "Union Operation"
The code, i am using is shown below:
Private Sub CommandButton1_Click()
Dim BoxObject As Acad3DSolid
Dim CylinderObject As Acad3DSolid
Dim startPoint(0 To 2) As Double
Dim endPoint(0 To 2) As Double
Dim n As Integer
Dim myapp As Object
Dim mydwg As AcadDocument
Dim acad As AcadApplication 'Create ACAD variable of type AcadApplication?
Dim Coords(0 To 2) As Double 'This is an array of double precision floating point numbers
On Error GoTo errorhandler
Set myapp = GetObject(, "Autocad.application")
errorhandler:
If Err.Description <> "" Then
Err.Clear
Set myapp = CreateObject("autocad.application")
End If
On Error Resume Next 'This tells VBA to ignore errors
Set acad = GetObject(, "AutoCAD.Application")
On Error GoTo 0 'This tells VBA to go back to NOT ignoring errors
If acad Is Nothing Then 'Check to see if the above worked
Set acad = New AcadApplication 'Set the ACAD variable to equal a new instance of ?AutoCAD
acad.Visible = True 'Once loaded, set AutoCAD® to be visible
End If
myapp.Visible = True
Dim BoxCenter(0 To 2) As Double
Dim BoxLength As Double, BoxWidth As Double
Dim BoxHeight As Double
Dim CylinderCenter(0 To 2) As Double
Dim CylinderXDistance As Double, CylinderYDistance As Double
Dim CylinderHeight As Double
BoxCenter(0) = Sheet1.Cells(3, 14)
BoxCenter(1) = Sheet1.Cells(4, 14)
BoxCenter(2) = Sheet1.Cells(5, 14)
BoxLength = Sheet1.Cells(6, 14)
BoxWidth = Sheet1.Cells(7, 14)
BoxHeight = Sheet1.Cells(8, 14)
acad.ActiveDocument.ModelSpace.AddBox BoxCenter, BoxLength, BoxWidth, BoxHeight
CylinderCenter(0) = Sheet1.Cells(10, 14)
CylinderCenter(1) = Sheet1.Cells(11, 14)
CylinderCenter(2) = Sheet1.Cells(12, 14)
cylinderRadius = Sheet1.Cells(13, 14)
CylinderHeight = Sheet1.Cells(14, 14)
acad.ActiveDocument.ModelSpace.AddCylinder CylinderCenter, cylinderRadius, CylinderHeight
Dim ViewDirection(0 To 2) As Double
ViewDirection(0) = 3#
ViewDirection(1) = -2.5
ViewDirection(2) = 1.5
Set mydwg = myapp.ActiveDocument
Sheet1.Cells(1, 5).Value = mydwg.Name
For n = 2 To 10
startPoint(0) = Sheet1.Cells(n, 1) 'Put the Column 1 value into the Coords array
startPoint(1) = Sheet1.Cells(n, 2) 'Put the Column 2 value into the Coords a
startPoint(2) = Sheet1.Cells(n, 3)
endPoint(0) = Sheet1.Cells(n + 1, 1) 'Put the Column 1 value into the Coords array
endPoint(1) = Sheet1.Cells(n + 1, 2) 'Put the Column 2 value into the Coords a
endPoint(2) = Sheet1.Cells(n + 1, 3)
acad.ActiveDocument.ModelSpace.AddLine startPoint, endPoint
Next
startPoint(0) = 25#
startPoint(1) = 25#
startPoint(2) = 0#
endPoint(0) = 30#
endPoint(1) = 30#
endPoint(2) = 0#
Dim length As Double, width As Double, height As Double
Dim center(0 To 2) As Double
Dim cylinderObj As Acad3DSolid
CylinderCenter(0) = 0#: CylinderCenter(1) = 0#: CylinderCenter(2) = 0#
cylinderRadius = 5#
CylinderHeight = 20#
Dim NewDirection(0 To 2) As Double
NewDirection(0) = -1: NewDirection(1) = -1: NewDirection(2) = 1
ZoomAll
End Sub
Alfred.NESWADBA
May I ask why you have not added the last 3 lines of >>>this sample<<< you seem to have found already?
Your code ends with
ZoomAll
And the (complete) sample ends with
ZoomAll
 ' Perform an intersection on the two solids
MsgBox "Perform an intersection on the two solids.", vbOKOnly, "Boolean Example"
boxObj.Boolean acIntersection, cylinderObj
ThisDrawing.Regen True
MsgBox "Intersection complete.", , "Boolean Example"
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
My code stop and give error at the highlight red color line "
Set boxObj ="
' This example creates a box and a cylinder in model space.
' It then performs a Boolean operation on the two solids.
Dim boxObj As Acad3DSolid
Dim boxLength As Double, boxWidth As Double, boxHeight As Double
Dim boxCenter(0 To 2) As Double
boxCenter(0) = 5#: boxCenter(1) = 5#: boxCenter(2) = 0
boxLength = 10#: boxWidth = 7: boxHeight = 10#
' Create the box (3DSolid) object in model space
Set boxObj = ThisDrawing.ModelSpace.AddBox(boxCenter, boxLength, boxWidth, boxHeight)
Dr. Abubakr Abdelwahab
Alfred.NESWADBA
Are you working in AutoCAD-VBA? Or from any other VBA-application?
If you get an error and highlighting of any lines please show a screenshot, because by default you don't just get a line marked, you also get a error description.
- alfred -
Alfred NESWADBA
Alfred.NESWADBA
well, the message box tells you what's wrong: "Object required" and that means that something is not initialized.
From what the marked line shows I guess it's the "ThisDrawing" object that might not me initialized.
I have looked now to other threads from your profile and there exists >>>that thread here<<< that handles the same question and that gives great suggestions from @norman.yuan. So why starting a new thread then? And have you tried to follow the suggestions from Norman?
- alfred -
Alfred NESWADBA
