How to access object properties in VBA?
I made a slice in a point cloud and now I want to change its position with VBA-code. It's position is in the properties. How can I retrieve and modify the desired properties in VBA?
Thank you in advance,
A newbie Autocad VBA programmer
Ed__Jobe
How did you create the slice? Is it a standard Section object?
Ed
How to post your code.
Hi @Ed__Jobe
I used the command 'sectionplane' on a rcp-pointcloud. Here I have selected the type: 'slice'. This is shown in the image below.
I also marked 'Section Offset' in properties. This is the value that I want to be able to modify via VBA.
Section of a pointcloudSection of a pointcloud
Ed__Jobe
That creates a vba Section object. You can edit the Section.SectionPlaneOffset property. Once you have the user select the section, set a variable of Section type and then access it's properties.
Ed
hi @Ed__Jobe
Thank you for your answer.
How would I encode that?
Kind regards
Ed__Jobe
Here you go.
Sub SectionTest()
    Dim sec As AcadSection
    Dim oEnt As AcadEntity
    Dim pp As Variant
GetEnt:
    ThisDrawing.Utility.getEntity oEnt, pp, "Select an Section object: "
    If TypeOf oEnt Is AcadSection Then
        Set sec = oEnt
        sec.SectionPlaneOffset = 120
    Else
        ThisDrawing.Utility.Prompt "You didn not select a Section object. Try again. "
        GoTo GetEnt
End Sub
Ed
It's working perfectly. Thank you very much @Ed__Jobe !
