Public TBUF1_Year As String
Public TBUF1_Month As String
Public TBUF1_GroupNo As String
Public TBUF1_Title As String
Public YYYYMMArr() As String
Public TBUF1_YYYYMM As String
Function TBFH121_Call_RemoveListLoaiTruFromProjectNameList(ProjectNameList As Variant, ListLoaiTru As Variant)
Dim EachProjectName As String
Dim IsInList As Boolean
Dim Result() As String
For i = LBound(ProjectNameList) To UBound(ProjectNameList)
EachProjectName = ProjectNameList(i)
IsInList = HCF4086_IsInArr1Chieu_NumberOrString(ListLoaiTru, EachProjectName)
If IsInList = False Then
ReDim Preserve Result(0 To k)
Result(k) = EachProjectName
k = k + 1
End If
Next
ProjectNameList = Result
End Function
Function Func000Array03FilterArrWithText(Arr As Variant, StrFilter As String, FilterColumn As Integer) As Variant
' Loc mang 2 chieu voi StrFilter va FilterColumn
Dim FilterArr() As Variant
'Neu Arr rong thi thoat function
If Func70IsEmptyArray(Arr) = True Then GoTo ExitFunc
'Tao TmpArr de luu tru so hang thoa man dieu kien
Dim TmpArr() As Variant
Dim TmpValue As Variant
Dim k As Integer
Dim i As Integer
For i = LBound(Arr) To UBound(Arr)
TmpValue = Arr(i, FilterColumn)
If TmpValue = StrFilter Then
ReDim Preserve TmpArr(0 To k)
TmpArr(k) = i
k = k + 1
End If
Next
'Neu k tim thay gia tri phu hop thi thoat function
If Func70IsEmptyArray(TmpArr) = True Then GoTo ExitFunc
'Tao Arr ket qua
Dim FilterArrRow As Integer
Dim FilterArrColumn As Integer
FilterArrRow = UBound(TmpArr)
FilterArrColumn = UBound(Arr, 2)
ReDim FilterArr(0 To FilterArrRow, 0 To FilterArrColumn)
For i = LBound(TmpArr) To UBound(TmpArr)
TmpValue = TmpArr(i)
For k = LBound(FilterArr, 2) To UBound(FilterArr, 2)
FilterArr(i, k) = Arr(TmpValue, k)
Next
Next
ExitFunc:
Func000Array03FilterArrWithText = FilterArr
End Function
Function Func000Array04CrearArrFromRange(WS As Worksheet, MainColumnLetter As String, ColumnFromLetter As String, ColumnToLetter As String, RowFrom As Integer) As Variant
' Tao mang 2 chieu tu Range
Dim Arr() As Variant
'Define Column no
Dim ColumnFromNo As Integer
Dim ColumnToNo As Integer
Dim MainColumnNo As Integer
ColumnFromNo = Func29ConvertColumnLetterToNumber(ColumnFromLetter)
ColumnToNo = Func29ConvertColumnLetterToNumber(ColumnToLetter)
MainColumnNo = Func29ConvertColumnLetterToNumber(MainColumnLetter)
'Define EndRow no, neu k co du lieu thi thoat
Dim EndRow As Integer
EndRow = WS.Cells(Rows.Count, MainColumnNo).End(xlUp).Row
If EndRow < RowFrom Then Exit Function
'Define Arr TotalColumn va TotalRow
Dim ArrTotalColumn As Integer
Dim ArrTotalRow As Integer
Dim ArrColumn As Integer
Dim ArrRow As Integer
Dim TmpValue As String
ArrTotalColumn = ColumnToNo - ColumnFromNo
ArrTotalRow = EndRow - RowFrom
ReDim Arr(0 To ArrTotalRow, 0 To ArrTotalColumn)
For i = RowFrom To EndRow
ArrRow = i - RowFrom
For k = ColumnFromNo To ColumnToNo
ArrColumn = k - ColumnFromNo
TmpValue = WS.Cells(i, k).Value
Arr(ArrRow, ArrColumn) = TmpValue
Next
Next
Func000Array04CrearArrFromRange = Arr
End Function
Function Func000Array01Lay1DongOMang2Chieu(MotherArr As Variant, RowNo As Integer) As Variant
'Function lay 1 dong trong mang 2 chieu
Dim SonArr() As Variant
For i = LBound(MotherArr, 2) To UBound(MotherArr, 2)
ReDim Preserve SonArr(0 To i)
SonArr(i) = MotherArr(RowNo, i)
Next
Func000Array01Lay1DongOMang2Chieu = SonArr
End Function
Function Func000Array02WriteArr1ChieuToRange(WriteArr As Variant, WS As Worksheet, StrCell As String, HorizonVertical As String)
' Ghi du lieu cua mang 1 chieu vao excel theo 2 huong ngang hoac doc
'Neu WriteArr rong thi thoat function
If Func70IsEmptyArray(WriteArr) = True Then Exit Function
'Define ColumnPlus va RowPlus
Dim ColumnPlus As Integer
Dim RowPlus As Integer
Select Case HorizonVertical
Case "Horizon"
RowPlus = 0
ColumnPlus = 1
Case "Vertical"
RowPlus = 1
ColumnPlus = 0
End Select
'Define CellRow and CellColumn from StrCell
Dim Range As Range
Set Range = WS.Range(StrCell)
Dim CellRow As Integer
Dim CellColumn As Integer
CellRow = Range.Row
CellColumn = Range.Column
'Write Data
Dim g, h As Integer
For i = LBound(WriteArr) To UBound(WriteArr)
WS.Cells(CellRow + g, CellColumn + h).Value = WriteArr(i)
g = g + RowPlus
h = h + ColumnPlus
Next
End Function
Function HCF4068_SortArrAtoZ_Arr2Chieu(Arr As Variant, SortRowNo As Integer, StringNumberMode As String) As Variant
' Sap xep cac phan tu cua mang theo thu tu tu A den Z
'Check input
If Func70IsEmptyArray(Arr) = True Then Exit Function
If SortRowNo > UBound(Arr, 2) Then Exit Function
If UBound(Arr) - LBound(Arr) = 0 Then Exit Function
Dim TmpArr As Variant
TmpArr = Arr
Dim SmallValue As Variant
Dim LargeValue As Variant
Dim Hoandoi As Boolean
For i = LBound(TmpArr, 1) To UBound(TmpArr, 1)
For k = i + 1 To UBound(TmpArr, 1)
Hoandoi = False
SmallValue = TmpArr(i, SortRowNo)
LargeValue = TmpArr(k, SortRowNo)
Select Case StringNumberMode
Case "String"
If StrComp(SmallValue, LargeValue) = 1 Then Hoandoi = True
Case "Number"
If SmallValue > LargeValue Then Hoandoi = True
End Select
If Hoandoi = True Then
For f = LBound(TmpArr, 2) To UBound(TmpArr, 2)
SmallValue = TmpArr(i, f)
LargeValue = TmpArr(k, f)
TmpValue = SmallValue
TmpArr(i, f) = LargeValue
TmpArr(k, f) = TmpValue
Next
End If
Next
Next
HCF4068_SortArrAtoZ_Arr2Chieu = TmpArr
End Function
Function HCF4080_DefineColumnEndNo(WS As Worksheet, EndColumn As Integer, RowNo As Integer)
EndColumn = WS.Cells(RowNo, Columns.Count).End(xlToLeft).Column
End Function
Function Func70IsEmptyArray(anArray As Variant) As Boolean
Dim i As Integer
Func70IsEmptyArray = True
On Error GoTo ExitFunction
i = UBound(anArray)
Func70IsEmptyArray = False
ExitFunction:
End Function
Function TBFH120_Call_CreatListLoaiTru(ListLoaiTru() As String)
ReDim ListLoaiTru(0 To 4)
ListLoaiTru(0) = ""
ListLoaiTru(1) = "—L‹xF”¼‹xE“Á‹x"
ListLoaiTru(2) = "‡ŒvŽžŠÔ"
ListLoaiTru(3) = "’‹L—“"
ListLoaiTru(4) = "‹Î‘Ó“à—e"
End Function
Function TBFH115_Call_DefineYearMonthFromYYYYMM(YYYYMM As String, YYYY As String, M As String)
YYYY = Left(YYYYMM, 4)
M = Right(YYYYMM, 2)
M = WorksheetFunction.Text(M, "0")
End Function
Function TBFH116_FilterDataInDataBaseByGroupNo_Year_Month(YYYY As String, M As String, GroupNo As String) As Variant
'Filter Data in Database by GroupNo,TBUF1_Year, TBUF1_Month
'Setting Sheet
Dim DBWS As Worksheet
Dim GroupSheet As Worksheet
Dim DBEndRow As Integer
Set DBWS = ThisWorkbook.Sheets(DBSheetname)
Set GroupSheet = ThisWorkbook.Sheets(GroupSheetname)
Call HCF4079_DefineRowEndNo(DBWS, DBEndRow, 1)
'Define Filter
Dim FilterRowArr() As Integer
Dim DByyyy As String
Dim Dbm As String
Dim DBGroupNo As String
For i = 2 To DBEndRow
DByyyy = DBWS.Cells(i, 1).Value
Dbm = DBWS.Cells(i, 2).Value
DBGroupNo = DBWS.Cells(i, 3).Value
If DByyyy = YYYY And Dbm = M And DBGroupNo = GroupNo Then
ReDim Preserve FilterRowArr(0 To k)
FilterRowArr(k) = i
k = k + 1
End If
Next
If k = 0 Then
TBFH116_FilterDataInDataBaseByGroupNo_Year_Month = False
Exit Function
End If
'Creat FilterDataArr
Dim FilterDataArr() As String
ReDim FilterDataArr(0 To k - 1, 0 To 4)
Dim RowNo As Integer
Dim DBStaffName As String
Dim DBProjectCode As String
Dim DBCustomerName As String
Dim DBProjectName As String
Dim DBTotal As String
For i = LBound(FilterDataArr) To UBound(FilterDataArr)
RowNo = FilterRowArr(i)
DBStaffName = DBWS.Cells(RowNo, 6).Value
DBProjectCode = DBWS.Cells(RowNo, 7).Value
DBCustomerName = DBWS.Cells(RowNo, 8).Value
DBProjectName = DBWS.Cells(RowNo, 9).Value
DBTotal = DBWS.Cells(RowNo, 41).Value
FilterDataArr(i, 0) = DBStaffName
FilterDataArr(i, 1) = DBProjectCode
FilterDataArr(i, 2) = DBCustomerName
FilterDataArr(i, 3) = DBProjectName
FilterDataArr(i, 4) = DBTotal
Next
TBFH116_FilterDataInDataBaseByGroupNo_Year_Month = FilterDataArr
End Function
Function TBFH117_Call_CreatProjectNameListFromArr(Arr As Variant, ProjectNameList As Variant)
'Get One Column In Arr
Call TBFH118_Call_GetOneColumnInArr(Arr, ProjectNameList, 3)
'Remove Dup Value in ProjectNameList
Call TBFH119_Call_RemoveDupValueInArr1Chieu(ProjectNameList)
'Creat ListLoaiTru
Dim ListLoaiTru() As String
Call TBFH120_Call_CreatListLoaiTru(ListLoaiTru)
'Remove ListLoaiTru From ProjectNameList
Call TBFH121_Call_RemoveListLoaiTruFromProjectNameList(ProjectNameList, ListLoaiTru)
End Function
Function TBFH118_Call_GetOneColumnInArr(OriginArr As Variant, ResultArr As Variant, GetColumnNo As Integer)
ReDim ResultArr(0 To UBound(OriginArr))
For i = LBound(OriginArr) To UBound(OriginArr)
ResultArr(i) = OriginArr(i, GetColumnNo)
Next
End Function
Function TBFH119_Call_RemoveDupValueInArr1Chieu(Arr As Variant)
Dim AfterRemoveDup() As Variant
Dim k As Integer
If k = 0 Then
ReDim Preserve AfterRemoveDup(0 To k)
AfterRemoveDup(k) = Arr(i)
k = k + 1
Else
IsInList = HCF4086_IsInArr1Chieu_NumberOrString(AfterRemoveDup, Arr(i))
k = k + 1
End If
End If
Next
Arr = AfterRemoveDup
End Function
Function TBFH122_Call_WriteArr2ChieuToRange(Arr As Variant, WS As Worksheet, RowFromNo As Integer, ColumnFromNo As Integer, WriteArrColumnFrom As Integer, WriteArrColumnTo As Integer)
Dim EachValue As String
Dim ColumnNo As Integer
ColumnNo = ColumnFromNo
For k = WriteArrColumnFrom To WriteArrColumnTo
EachValue = Arr(i, k)
WS.Cells(RowFromNo, ColumnNo).Value = EachValue
ColumnNo = ColumnNo + 1
Next
RowFromNo = RowFromNo + 1
Next
End Function
Function TBFH123_Call_SetWorksheet()
Set StaffManagerWS = ThisWorkbook.Sheets(StaffManagerSheetname)
Set ProjectManagerWS = ThisWorkbook.Sheets(ProjectSheetname)
Set GroupWS = ThisWorkbook.Sheets(GroupSheetname)
End Function
Function TBFH124_Call_GroupSheet_ClearOldData()
'Clear Group StaffName
GroupWS.Range("E2:AZ2").ClearContents
'Clear ProjectRange
GroupWS.Range("A3:AZ49").ClearContents
'Clear Zakken
GroupWS.Range("D50:AZ59").ClearContents
'Show Hidden row
GroupWS.Range("A3:A49").EntireRow.Hidden = False
End Function
Function TBFH125_Call_GroupSheet_WriteNote(YYYY As String, M As String)
Dim GroupNote As String
GroupNote = YYYY & "”N" & M & "ŒŽ“x‹qæ•ÊŽžŠÔWŒv•\"
GroupWS.Cells(1, 1).Value = GroupNote
End Function
Function TBFH126_Call_WriteGroupStaffname(GroupNo As String)
'Creat StaffManagerArr
Call TBFH127_Call_CreatStaffManagerArr
'Filter With GroupNo
StaffManagerArr = Func000Array03FilterArrWithText(StaffManagerArr, GroupNo, 4)
'Lay chi Staffname
Dim StaffnameArr As Variant
StaffnameArr = TBFH128_Lay1CotTrongMang2Chieu(StaffManagerArr, 2)
'Write to GroupSheet
Call Func000Array02WriteArr1ChieuToRange(StaffnameArr, GroupWS, "E2", "Horizon")
End Function
Function TBFH127_Call_CreatStaffManagerArr()
Call TBFH123_Call_SetWorksheet
StaffManagerArr = TBFH102_CrearArrFromRange(StaffManagerWS, "C", "A", "G", 2)
End Function
Function TBFH128_Lay1CotTrongMang2Chieu(MotherArr As Variant, ColumnNo As Integer) As Variant
ReDim SonArr(LBound(MotherArr) To UBound(MotherArr))
Dim EachValue As Variant
For i = LBound(MotherArr) To UBound(MotherArr)
SonArr(i) = MotherArr(i, ColumnNo)
Next
TBFH128_Lay1CotTrongMang2Chieu = SonArr
End Function
Function TBFH129_Call_GroupSheet_WriteProjectName(ProjectNameList As Variant)
Dim PMEndRow As Integer
Dim PMProjectName As String
Dim WriteRowNo As Integer: WriteRowNo = 3
Call HCF4079_DefineRowEndNo(ProjectManagerWS, PMEndRow, 3)
For i = 2 To PMEndRow
PMProjectName = ProjectManagerWS.Cells(i, 3).Value
IsInList = HCF4086_IsInArr1Chieu_NumberOrString(ProjectNameList, PMProjectName)
If IsInList = True Then
GroupWS.Cells(WriteRowNo, 1).Value = ProjectManagerWS.Cells(i, 1).Value
GroupWS.Cells(WriteRowNo, 2).Value = ProjectManagerWS.Cells(i, 2).Value
GroupWS.Cells(WriteRowNo, 3).Value = ProjectManagerWS.Cells(i, 3).Value
WriteRowNo = WriteRowNo + 1
End If
Next
End Function
Function TBFH130_Call_GroupSheet_WriteData(WriteData As Variant)
Dim GEndRow As Integer: GEndRow = 58
Dim GEndColumn As Integer
Call HCF4080_DefineColumnEndNo(GroupWS, GEndColumn, 2)
Dim EachName As String
Dim EachCustomerName As String
Dim EachTime As String
Dim GetRowNo As Variant
Dim GetColumnNo As Variant
Dim WriteColumnNo As Integer
For i = LBound(WriteData) To UBound(WriteData)
EachName = WriteData(i, 0)
EachCustomerName = WriteData(i, 2)
EachProjectName = WriteData(i, 3)
EachTime = WriteData(i, 4)
GetRowNo = TBFH133_DefineRowNoOfProjectNameInGroupSheet(EachCustomerName, EachProjectName, 3, GEndRow)
GetColumnNo = TBFH131_DefineColumnNoOfValue(EachName, GroupWS, 2, 5, GEndColumn)
If VarType(GetRowNo) <> vbBoolean And VarType(GetColumnNo) <> vbBoolean Then
GroupWS.Cells(GetRowNo, GetColumnNo).Value = EachTime
End If
Next
'Sum Row
For RowNo = 3 To 58
Call TBFH134_SumRow(GroupWS, RowNo, 5, GEndColumn, 4)
Next
'Sum Column
For ColumnNo = 4 To GEndColumn
Call TBFH135_SumColumn(GroupWS, ColumnNo, 3, 58, 59)
Next
End Function
Function TBFH131_DefineColumnNoOfValue(LookupValue As String, WS As Worksheet, RowNo As Integer, ColumnFrom As Integer, ColumnTo As Integer) As Variant
Dim ResultColumnNo As Integer
Dim CompareValue As String
For i = ColumnFrom To ColumnTo
CompareValue = WS.Cells(RowNo, i).Value
If CompareValue = LookupValue Then
TBFH131_DefineColumnNoOfValue = i
Exit Function
End If
Next
TBFH131_DefineColumnNoOfValue = False
End Function
Function TBFH132_DefineRowNoOfValue(LookupValue As String, WS As Worksheet, ColumnNo As Integer, RowFrom As Integer, RowTo As Integer) As Variant
Dim ResultRowNo As Integer
For i = RowFrom To RowTo
CompareValue = WS.Cells(i, ColumnNo).Value
TBFH132_DefineRowNoOfValue = i
Exit Function
End If
Next
TBFH132_DefineRowNoOfValue = False
End Function
Function TBFH133_DefineRowNoOfProjectNameInGroupSheet(CustomerName As String, ProjectName As String, RowFrom As Integer, RowTo As Integer) As Variant
Dim LookupValue As String
LookupValue = CustomerName & "-" & ProjectName
CompareValue = GroupWS.Cells(i, 2).Value & "-" & GroupWS.Cells(i, 3).Value
TBFH133_DefineRowNoOfProjectNameInGroupSheet = i
Exit Function
End If
Next
TBFH133_DefineRowNoOfProjectNameInGroupSheet = False
End Function
Function TBFH134_SumRow(WS As Worksheet, RowNo As Integer, ColumnFrom As Integer, ColumnTo As Integer, WriteResultColumn As Integer)
Dim SumRow As Double
Dim EachCell As Variant
EachCell = WS.Cells(RowNo, i).Value
If EachCell <> "" Then
EachCell = CDbl(EachCell)
SumRow = SumRow + EachCell
End If
Next
If SumRow = 0 Then
WS.Cells(RowNo, WriteResultColumn).Value = ""
Else
WS.Cells(RowNo, WriteResultColumn).Value = SumRow
End If
End Function
Function TBFH135_SumColumn(WS As Worksheet, ColumnNo As Integer, RowFrom As Integer, RowTo As Integer, WriteResultRow As Integer)
Dim SumColumn As Double
EachCell = WS.Cells(i, ColumnNo).Value
SumColumn = SumColumn + EachCell
End If
Next
If SumColumn = 0 Then
WS.Cells(WriteResultRow, ColumnNo).Value = ""
Else
WS.Cells(WriteResultRow, ColumnNo).Value = SumColumn
End If
End Function
Function TBFH136_Call_GroupSheet_HideEmptyRow()
Dim CheckValue As String
For RowNo = 3 To 49
CheckValue = GroupWS.Cells(RowNo, 4).Value
If CheckValue = "" Then
GroupWS.Range("A" & RowNo).EntireRow.Hidden = True
End If
Next
End Function
Sub TBS101_CreatGroupSheet()
Application.ScreenUpdating = False
Application.EnableEvents = False
'Set worksheet
'Get Year, Month From SystemDate
Dim SystemYear As String: SystemYear = "2021"
Dim SystemMonth As String: SystemMonth = "4"
'Get Year, Month From DataBase
Dim DBYearMonth(0 To 11, 0 To 1) As String
DBYearMonth(0, 0) = "2021": DBYearMonth(0, 1) = "1"
DBYearMonth(1, 0) = "2021": DBYearMonth(1, 1) = "2"
DBYearMonth(2, 0) = "2021": DBYearMonth(2, 1) = "3"
DBYearMonth(3, 0) = "2021": DBYearMonth(3, 1) = "4"
DBYearMonth(4, 0) = "2021": DBYearMonth(4, 1) = "5"
DBYearMonth(5, 0) = "2021": DBYearMonth(5, 1) = "6"
DBYearMonth(6, 0) = "2021": DBYearMonth(6, 1) = "7"
DBYearMonth(7, 0) = "2021": DBYearMonth(7, 1) = "8"
DBYearMonth(8, 0) = "2021": DBYearMonth(8, 1) = "9"
DBYearMonth(9, 0) = "2021": DBYearMonth(9, 1) = "10"
DBYearMonth(10, 0) = "2021": DBYearMonth(10, 1) = "11"
DBYearMonth(11, 0) = "2021": DBYearMonth(11, 1) = "12"
Call TBFH114_Call_CreatYYYYMMArrFromDBYearMonth(DBYearMonth)
'Check SystemYearSystemMonth is in DBYearMonth
Dim IsInDBYearMonth As Boolean
IsInDBYearMonth = TBFH113_Check2ValueIsInArr2Chieu_NumberOrString(DBYearMonth, SystemYear, 0, SystemMonth, 1)
If IsInDBYearMonth = True Then
SystemMonth = WorksheetFunction.Text(SystemMonth, "00")
TBUF1_YYYYMM = SystemYear & "." & SystemMonth
Else
TBUF1_YYYYMM = YYYYMMArr(UBound(YYYYMMArr))
End If
'Get StaffName From PCNo
Dim StaffName As String
StaffName = "TUAN"
'Get GroupNo From StaffName
Dim GroupNo As String
Dim GroupName As String
GroupNo = TBFH105_GetStaffInformationFromPCNo_StaffID_StaffName(StaffName, "FromName", "GNo")
If GroupNo = "" Then GroupNo = "1G"
GroupName = TBFH112_DefineGroupNameFromGroupNo(GroupNo)
'Set TBUF1_GroupNo, TBUF1_Title
TBUF1_Title = GroupName
TBUF1_GroupNo = GroupNo
'Get Information From UserForm
TBUF1_GroupSheet.Show
If TBUF1_YYYYMM = "" Then
GoTo GoToExitSub
Else
Call TBFH115_Call_DefineYearMonthFromYYYYMM(TBUF1_YYYYMM, TBUF1_Year, TBUF1_Month)
End If
Dim GetFilterData As Variant
Dim FilterData() As String
GetFilterData = TBFH116_FilterDataInDataBaseByGroupNo_Year_Month(TBUF1_Year, TBUF1_Month, TBUF1_GroupNo)
If VarType(GetFilterData) = vbBoolean Then
MsgBox "Err:No Data"
GoTo GoToExitSub
Else
FilterData = GetFilterData
End If
'Creat and Sort FilterProjectNameList
Dim ProjectNameList As Variant
Call TBFH117_Call_CreatProjectNameListFromArr(FilterData, ProjectNameList)
'Clear Old Data
Call TBFH124_Call_GroupSheet_ClearOldData
'Write GroupSheetNote
Call TBFH125_Call_GroupSheet_WriteNote(TBUF1_Year, TBUF1_Month)
'Write Group StaffName
Call TBFH126_Call_WriteGroupStaffname(TBUF1_GroupNo)
'Write ProjectName
Call TBFH129_Call_GroupSheet_WriteProjectName(ProjectNameList)
'Write Data
Call TBFH130_Call_GroupSheet_WriteData(FilterData)
'Hide Empty Row
Call TBFH136_Call_GroupSheet_HideEmptyRow
GoToExitSub:
Application.ScreenUpdating = True
Application.EnableEvents = True
MsgBox "Finish"
End Sub
Function TBFH112_DefineGroupNameFromGroupNo(GroupNo As String) As String
Select Case GroupNo
Case "1G"
TBFH112_DefineGroupNameFromGroupNo = "’†’¬G"
Case "2G"
TBFH112_DefineGroupNameFromGroupNo = "ŒÃ‰ÆG"
End Select
End Function
Function TBFH113_Check2ValueIsInArr2Chieu_NumberOrString(ListArr As Variant, LookupValue1 As Variant, LookupColumnNo1 As Integer, LookupValue2 As Variant, LookupColumnNo2 As Integer) As Boolean
Dim CompareValue1 As Variant
Dim CompareValue2 As Variant
For i = LBound(ListArr) To UBound(ListArr)
CompareValue1 = ListArr(i, LookupColumnNo1)
CompareValue2 = ListArr(i, LookupColumnNo2)
If CompareValue1 = LookupValue1 And CompareValue2 = LookupValue2 Then
TBFH113_Check2ValueIsInArr2Chieu_NumberOrString = True
Exit Function
End If
Next
End Function
Function TBFH114_Call_CreatYYYYMMArrFromDBYearMonth(DBYearMonth() As String)
ReDim Preserve YYYYMMArr(0 To UBound(DBYearMonth))
Dim EachYear As String
Dim EachMonth As String
Dim EachYYYYMM As String
For i = 0 To UBound(DBYearMonth)
EachYear = DBYearMonth(i, 0)
EachMonth = DBYearMonth(i, 1)
EachMonth = WorksheetFunction.Text(EachMonth, "00")
EachYYYYMM = EachYear & "." & EachMonth
YYYYMMArr(i) = EachYYYYMM
Next
End Function
Sub TBS102_SortProjectNameA2Z()
'Define WS
Dim PMWS As Worksheet
Set PMWS = ThisWorkbook.Sheets(ProjectSheetname)
'Creat ProjectNameArr From Range
Dim ProjectNameArr As Variant
ProjectNameArr = Func000Array04CrearArrFromRange(PMWS, "C", "A", "Q", 2)
'Creat SortProjectNameArr
Dim SortProjectNameArr As Variant
Dim EachGroupNo As String
Dim EachSort As String
ReDim SortProjectNameArr(0 To UBound(ProjectNameArr, 1), 0 To UBound(ProjectNameArr, 2) + 1)
For i = LBound(SortProjectNameArr) To UBound(SortProjectNameArr)
For k = LBound(ProjectNameArr, 2) To UBound(ProjectNameArr, 2)
SortProjectNameArr(i, k) = ProjectNameArr(i, k)
Next
EachGroupNo = ProjectNameArr(i, 3)
EachCustomerName = ProjectNameArr(i, 1)
EachProjectName = ProjectNameArr(i, 2)
EachSort = EachGroupNo & "-" & EachCustomerName & "-" & EachProjectName
SortProjectNameArr(i, UBound(SortProjectNameArr, 2)) = EachSort
Next
'Sort A2Z by GroupNo CustomerName ProjectName
SortProjectNameArr = HCF4068_SortArrAtoZ_Arr2Chieu(SortProjectNameArr, 17, "String")
'Write Arr to Range
Call TBFH122_Call_WriteArr2ChieuToRange(SortProjectNameArr, PMWS, 2, 1, 0, 16)
MsgBox "Finish"
End Sub
