How do you use an asterisk to search for layers using VBA?
JustinSider
JustinSider
Hi guys, I thought this would be easy but it's just not working for me and I've searched the help, these forums and I can't find anything.
When you search for a layer in CAD, if you put *TEXT* any layer with TEXT in the name will appear.  This doesn't work when writing code though!!   My example is shown below which doesn't work......  without the asterisk (*) it will change the layer "New" to "MEPHAN" but I want all layers with the word "New" to be changed to "MEPHAN".. (example "xref_New", "New_copy", etc).  The asterisk is supposed to be for a string of characters, don't see why it doesn't work.  Also, is there any character for a sequence of numbers?  the (#) symbol only works for single numbers.
Dim oLayers As AcadLayers
Set oLayers = ThisDrawing.Layers
Dim oLayer As AcadLayer
Dim ent As AcadEntity
For Each ent In ThisDrawing.ModelSpace
If ent.Layer = "*New*" Then
ent.Layer = "MEPHAN"
Next
Thanks for any input!!
Ed__Jobe
Notice the "=", its doing exactly what its supposed to do. You need to learn the functions for working with strings. In the vba help, look up "strings, manipulating" in the index. It lists the various string functions. Use the "Like" operator instead of the "=" operator. Help on Like has info on wildcards.
Ed
How to post your code.
JustinSider
YEs!  ****, I remember reading this in my book.... Okay I got this now, thanks a bunch!!
