How do I Toggle a picture on a button?
I'm trying to get a picture on a command button to toggle to another picture when picked. I have got the process to work using the MyButton.Picture=LoadPicture("mypath") method. However, I was wanting to use a bitmap that I have saved inside one of my DLL files I use for my toolbars bitmaps. Can that be done? Is it possible to use a picture from a DLL file or am I stuck with having to hard code the path to my picture files?
I'm at a lost and I hope there is an way to do this. Any suggestion and advice would be greatly appreciated. Thanks in advance.
Jcurley@rbf.com
"jcurley" wrote in message
news:f1272fc.-1@WebX.maYIadrTaRb...
In the button's Click event, check a global variable to determine which
picture to load.
> Can that be done?
Yes. Although I forget the exact method, have a look in the Downloads
section of my site for ImageView.cls. It contains code that retrieves
bitmaps from ACADBTN.DLL. I'm sure you can adapt it to work with any
resource DLL.
There are 10 kinds of people:
Those who understand binary and those who don't
http://www.acadx.com
files?
Jcurley@rbf.com
it is very easy to put a picture in a command button, u don't need to make any coding to do that, only thing u have to do is to make that picture size smaller to fit the command icon, and paste it.
John
"jjin" wrote in message
news:f1272fc.1@WebX.maYIadrTaRb...
I'm sure jcurley wants to know how to change the button graphic at
runtime, not design time. This will require him to write some code.
