Take a look ath this page
http://www.cad.dp.ua/stats/a_vba/index.php
Choose English language at the very top right in this page , then
scroll down to "AutoCAD Objects" --> "Menus and Toolbars"
thank you very much
Dim currMenuGroup As AcadMenuGroup Set currMenuGroup = ThisDrawing.Application.MenuGroups.Item(0) ' Create the new menu Dim newMenu As AcadPopupMenu Set newMenu = currMenuGroup.Menus.Add("TestMenu") ' Add a menu item to the new menu Dim newMenuItem As AcadPopupMenuItem Dim openMacro As String ' Assign the macro the VBA equivalent of "ESC ESC _open " openMacro = Chr(3) + Chr(3) + "_open " Set newMenuItem = newMenu.AddMenuItem(newMenu.Count + 1, "Open", openMacro) ' Display the menu on the menu bar newMenu.InsertInMenuBar (ThisDrawing.Application.MenuBar.Count + 1)
Don't forget error checking 😉
Public Sub AddMenus() 'Jonathan D. Kriek Dim currMenuGroup As AcadMenuGroup Dim newMenu As AcadPopupMenu Dim newMenuItem As AcadPopupMenuItem Set currMenuGroup = ThisDrawing.Application.MenuGroups.Item(0) On Error Resume Next 'Assign new menu Set newMenu = currMenuGroup.Menus.Item("TrinityTools") 'If menu doesn't exist then add it If newMenu Is Nothing Then Set newMenu = currMenuGroup.Menus.Add("TrinityTools") End If 'Check if Menu is displayed on MenuBar If Not newMenu.OnMenuBar Then 'Add the eBLoader macro to the menu Set newMenuItem = newMenu.AddMenuItem(newMenu.count + 1, _ "Release To eB", "-vbarun eBLoader ") newMenuItem.HelpString = "Release To eB" 'Add the DrawingTypeLoad macro to the menu Set newMenuItem = newMenu.AddMenuItem(newMenu.count + 1, _ "Set Drawing Type", "-vbarun DrawingTypeLoad ") newMenuItem.HelpString = "Set Drawing Type" 'Display the menu on the menu bar newMenu.InsertInMenuBar (ThisDrawing.Application.MenuBar.count + 1) End If 'Save menu currMenuGroup.Save (acMenuFileCompiled) End Sub
Since AutoCAD 2006 MenuGroup.Save do nothing, so it is impossible save menu created on fly with AutoCAD ActiveX Model.
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Ah, yes I forgot about the 2005 to 2006 changes.
Thanks, but the point of my post was error checking.
Your code ran but didn't add a new menu, is there anything I'm missing?
I'm using AutoCAD 2016.
