How Can I create a menu Using VBA
Amremad
Amremad
How Can I create a menu like file & edit & view using VBA
Hallex
Take a look ath this page
http://www.cad.dp.ua/stats/a_vba/index.php
Choose English language at the very top right in this page , then
scroll down to "AutoCAD Objects" --> "Menus and Toolbars"
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Amremad
thank you very much
Dim currMenuGroup As AcadMenuGroup
Set currMenuGroup = ThisDrawing.Application.MenuGroups.Item(0)
 ' Create the new menu
 Dim newMenu As AcadPopupMenu
 Set newMenu = currMenuGroup.Menus.Add("TestMenu")
 ' Add a menu item to the new menu
 Dim newMenuItem As AcadPopupMenuItem
 Dim openMacro As String
 ' Assign the macro the VBA equivalent of "ESC ESC _open "
 openMacro = Chr(3) + Chr(3) + "_open "
 Set newMenuItem = newMenu.AddMenuItem(newMenu.Count + 1, "Open", openMacro)
 ' Display the menu on the menu bar
 newMenu.InsertInMenuBar (ThisDrawing.Application.MenuBar.Count + 1)
jdkriek
Don't forget error checking 😉
Public Sub AddMenus()
'Jonathan D. Kriek
    On Error Resume Next
    'Assign new menu
    Set newMenu = currMenuGroup.Menus.Item("TrinityTools")
        'If menu doesn't exist then add it
        If newMenu Is Nothing Then
            Set newMenu = currMenuGroup.Menus.Add("TrinityTools")
        End If
            'Check if Menu is displayed on MenuBar
            If Not newMenu.OnMenuBar Then
                'Add the eBLoader macro to the menu
                Set newMenuItem = newMenu.AddMenuItem(newMenu.count + 1, _
                "Release To eB", "-vbarun eBLoader ")
                newMenuItem.HelpString = "Release To eB"
                'Add the DrawingTypeLoad macro to the menu
                "Set Drawing Type", "-vbarun DrawingTypeLoad ")
                newMenuItem.HelpString = "Set Drawing Type"
                'Display the menu on the menu bar
                newMenu.InsertInMenuBar (ThisDrawing.Application.MenuBar.count + 1)
            End If
        'Save menu
        currMenuGroup.Save (acMenuFileCompiled)
End Sub
Jonathan D. Kriek
MFG Solutions Engineer
KETIV Technologies, Inc.
Alexander.Rivilis
jdkriek wrote:
       'Save menu
Since AutoCAD 2006 MenuGroup.Save do nothing, so it is impossible save menu created on fly with AutoCAD ActiveX Model.
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
jdkriek
Ah, yes I forgot about the 2005 to 2006 changes.
Thanks, but the point of my post was error checking.
Jonathan D. Kriek
Your code ran but didn't add a new menu, is there anything I'm missing?
I'm using AutoCAD 2016.
