How can export OD to Xdata?
I want to export OD that attach to an object,export to "XData" for that object.
Is this possible?
i will thank you if can help me.
cheers,
Abbas
I believe you are talking about Object Data in AcadMap. I also believe OD in
AcadMap is actually XData (or Autodesk's custom XData). What do you exactly
want to do?
Yes, you can create XData to an entity and populate the XData with data from
OD, but probably there isn't a way out box, you have to do it yourself with,
say, VBA. It is fairly easy.
wrote in message news:5255806@discussion.autodesk.com...
object.
Is this possible?
cheers,
Abbas
