Hide Autocad activity while VBA program is in progress
Message 1 of 26
I have created a program with some quick plotting macros for our various layouts and printers. So far it seems to work fine. Although, while running, it shows autocad switching to paperspace, creating the viewport before switching back to modelspace again. Can this activity be hidden from the user? It would make the program more professional looking if it could be hidden.
Replies (25)
Message 2 of 26
arcticad
Declare Function LockWindowUpdate Lib "user32" (ByVal hwndLock As Long) As Long
LockWindowUpdate (ThisDrawing.hwnd)
' do stuff here
LockWindowUpdate (0)
(defun botsbuildbots() (botsbuildbots))
Message 3 of 26
jeremye86
your code is not working for me.  I gave up and just decided to use
acadApp.WindowState = acMin
Do you have any pointers when using your code?
Message 4 of 26
Ed__Jobe
Try
Declare PtrSafe Function LockWindowUpdate Lib "user32" (ByVal hwndLock As Long) As Long
Ed
How to post your code.
Message 5 of 26
jeremye86
Ed,
I am already using this and it works fine.
#If VBA7 And Win64 Then
Public Declare PtrSafe Function LockWindowUpdate Lib "user32" (ByVal hwndLock As LongPtr) As Long
#Else
Public Declare Function LockWindowUpdate Lib "user32" (ByVal hwndLock As Long) As Long
#End If
The only problem is im not sure what to put inside the function
LockWindowUpdate (???????.Hwnd)
right now i am doing this
Set acadApp = GetObject(, "AutoCAD.Application")
LockWindowUpdate (acadApp.Hwnd)
it seems to be working but the only thing it is hiding in the screen update is this
acadApp.Application.Documents.Add
where i don't see the additional document windows pop up
But i still see the actual drawing window doing screen updates (which i need turned off)
Message 6 of 26
Ed__Jobe
Use the handle of the document, ThisDrawing.HWND.
Edit, I see you might be running this from another app. Set a variable to the active document.
Dim oDoc as AcadDocument
Set oDoc = acadApp.ActiveDocument
LockWindowUpdate(oDoc.HWND)
Ed
Message 7 of 26
jeremye86
Ed,
You are correct, i am running the code from excel.
Unfortunately, what you just suggested is causing excel to crash and shut down.
It is interesting, when i change Dim oDoc as AcadDocument to Dim oDoc as object it does not crash, but i don't see the LockWindowUpdate function working correctly.
Message 8 of 26
Ed__Jobe
It would seem that you don't have the correct AutoCAD tlb referenced in Excel. Set a breakpoint in Excel and see which line causes the crash. It also sounds like you don't have any error checking in your sub. You should be getting an error to the effect "Can't create object" or something similar.
Ed
Message 9 of 26
jeremye86
it crashes right when i step into the procedure.
What do you mean 'you don't have the correct AutoCAD tlb referenced'?
Message 10 of 26
Ed__Jobe
 Do you have your breakpoint at the beginning of the sub?
If you are going to to use AutoCAD objects you have to reference its type library (*.tlb). Go to Tools>References and check the appropriate tlb for your version of AutoCAD. I thought you might be using an older reference.
Ed
Message 11 of 26
jeremye86
yes i have it break at the beginning of the sub.
i have the error trapping to break on all errors as well.  I also have the correct reference for autocad.  still no solution
this crashes excel
this does not crash excel
Dim oDoc as object
Message 12 of 26
Ed__Jobe
That's not error handling. Its the responsibility of your sub to determine what should happen when an error occurs. Below is a template of my standard error handling. What error number you should put in your Case..Select is a matter of trial and error. 🙂
Sub Main()
    On Error GoTo Err_Control
    'Do your work here.
Cleanup:
    Set oDwg = Nothing
    Set oDbx = Nothing
Exit_Here:
    Exit Sub
Err_Control:
    Select Case Err.Number
    'Add your Case selections here
    'Case Is = 1000
        'Handle error
        'Err.Clear
        'Resume Exit_Here
    Case Else
        MsgBox Err.Number & ", " & Err.Description, , "Main Title"
        Err.Clear
        Resume Exit_Here
    End Select
End Sub
After some research, I found this in an MSDN article.
Instead of LockWindowUpdate(hwnd)
Use SendMessage(hwnd, WM_SETREDRAW, FALSE, 0) or
SetWindowRedraw(hwnd, FALSE)
Instead of LockWindowUpdate(NULL)
Use SendMessage(hwnd, WM_SETREDRAW, TRUE, 0) or
SetWindowRedraw(hwnd, TRUE)
As we noted earlier, only one window in the system can be locked for update at a time. If your intention for calling LockWindowUpdate is merely to prevent a window from redrawing, say, because you're updating it and don't want the window continuously refreshing until your update is complete, then just disable redraw on that window. If you use LockWindowUpdate, you create a whole slew of subtle problems.
So...
Public Const WM_SETREDRAW = &HB
Declare PtrSafe Function SendMessage Lib "user32" (ByVal hWnd As Long, ByVal wMsg As Long, ByVal wParam As Long, ByVal lParam As Any) As Long
'Lock window redraw
SendMessage(oDoc.HWND, WM_SETREDRAW, FALSE, 0)
'Do work here
'Reset window redraw
SendMessage(oDoc.HWND, WM_SETREDRAW, TRUE, 0)
Ed
Message 13 of 26
jeremye86
thanks Ed for your insights
this line is giving an error
Message 14 of 26
Ed__Jobe
Did you implement the error handling I gave you and did you get an error number/description?
Ed
Message 15 of 26
jeremye86
its a syntax error
Message 16 of 26
Ed__Jobe
Try changing true/false to vbTrue/vbFalse.
Ed
Message 17 of 26
jeremye86
hey Ed, i still get a syntax error.
I guess i need to study up on windows API before i start using it.  thanks for all your help
Message 18 of 26
Ed__Jobe
You might have misspelled something or left out an argument. Post your code so we can have a look at it.
Ed
Message 19 of 26
jeremye86
i took out a lot for simplicity but here is the general idea of what i am doing
Option Explicit
Declare PtrSafe Function SendMessage Lib "user32" (ByVal hWnd As Long, ByVal wMsg As Long, ByVal wParam As Long, _
#Else
Declare Function SendMessage Lib "user32" (ByVal hWnd As Long, ByVal wMsg As Long, ByVal wParam As Long, _
#End If
Sub open_autocad()
    Dim acadApp As Object
    Dim oDoc As AcadDocument
    'Check if AutoCAD application is open. If it is not opened create a new instance and make it visible.
    On Error Resume Next
    acadApp.Visible = True
    If acadApp Is Nothing Then
        Set acadApp = CreateObject("AutoCAD.Application")
    'Check (again) if there is an AutoCAD object.
        MsgBox "Sorry, it was impossible to start AutoCAD!", vbCritical, "AutoCAD Error"
        Exit Sub
    On Error GoTo 0
    acadApp.WindowState = acMax
    SendMessage(oDoc.HWND, WM_SETREDRAW, vbfalse, 0)
    'do work here
    SendMessage(oDoc.HWND, WM_SETREDRAW, vbtrue, 0)
End Sub
Message 20 of 26
Ed__Jobe
Try
SendMessage oDoc.HWND, WM_SETREDRAW, 0&, 0
SendMessage oDoc.HWND, WM_SETREDRAW, 1&, 0
You only use the parenthesis when the function is on the right side of an equals sign, like when you are setting a variable to the value returned by the function.
Also, I changed the TRUE/FALSE to 1& and 0& because those constants are defined in .NET, but not VBA. vbTrue is a tristate and not quite the same.
Ed
