Help with VB Design's File Dialog Class
Message 1 of 14
I've been attempting to use the File Dialog Class from http://www.vbdesign.net/cadpages/code/source/file_dialogs.htm but I'm having no luck and I suspect it is because I am placing the code in the wrong location.
Can someone tell me if this code belongs in a module or a class or a combination of both? Also, I'm trying to use this in AutoCAD Map 2002. Will this existing code work in 2002? On that note, is this the best solution for prompting the user to open a drawing file or is there a simpler method that already exists?
Replies (13)
Message 2 of 14
I should also note that I'm pretty experienced with VBA, but do not have experience working with classes.
In other applications such as Excel, displaying the File Open dialog is very simple using the GetOpenFilename method and I'm extremely surprized that nothing exists like that in VBA for AutoCAD.
Message 3 of 14
The DrawingEditor class in the AcadX(tm) Active Extension
Library for AutoCAD (www.caddzone.com) has FileDialog()
and FileNavDialog() methods that allow you to use the same
Open/Save dialog that AutoCAD uses.
"geoback" wrote in message
news:[email protected]...
Message 4 of 14
The code from VBDesign belongs in a class module. You may
then use a standard module to create an instance of the class for your
project to use.
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
I've
href="http://www.vbdesign.net/cadpages/code/source/file_dialogs.htm">http://www.vbdesign.net/cadp...
the wrong location.
already exists?
Message 5 of 14
Hi Tony,
Thanks for your reply.
I had seen your AcadX extension library but your usage restrictions prevent
me from distributing the routine to my client. This is a fairly small job
therefore it wasn't worth getting into a license agreement.
I will defnitely keep you in mind if this job grows into something much
bigger.
Thanks again
"Tony Tanzillo" wrote in message
Message 6 of 14
I have created a class and put the vbdesign code into it. it won't compile. it says the public const data can't be public const...
Message 7 of 14
wrote in message news:[email protected]...
either move it into a std module or make it private
hth
Mark
Message 8 of 14
I moved it to a std module. I could not make it private because the contants would not be available for other codes use.
It is now working.
Message 9 of 14
just curious....why should they be available for other code's use? As I
understand it, a major point of class programing is to encapsulate bits of
code until functional objects, only exposing information through properties.
Though there are some instances where public variables can make sense, in
general they're best kept to a minimum.
-Chris
It is now working.
Message 10 of 14
The standard OPENFILENAME structure has to be populated with a varierty of flag values. You then pass your structure into the GetOpenFileName method. Thus those flags need to be known.
Standard MFC behavior always makes the flag constants public for this particular wrapper in Visual C++
Andrew
Message 11 of 14
True, but the whole point of creating a wrapper is so that you don't need to
be making the API calls all over the place. If the windows dialog wrapper
was implimented as a class then it could be the only code accessing the
OPENFILENAME API call directly and thus the data structure wouldn't need to
be declared as public. All dialog requests would be handled by the methods
and properties of the wrapper.
I'm not familiar with the VB design dialog class wrapper, but I know that's
how mine works.
-Chris
Andrew
Message 12 of 14
I know what you mean.
Message 13 of 14
fxcastil
go to link below an download "comm dialog .zip " this should work for you
http://discussion.autodesk.com/thread.jspa?threadID=451811
Fred Castillo
Message 14 of 14
Thanks. I got the vb designs one working.
Andrew
