Help with setting style & font with VBA
Message 1 of 13
I've attached this code to be run from 2 different buttons, one for the
RomanD and the other for the RomanS. The co. I work for basically uses these
2 fonts in their drawings and I was trying to automate the switching back
and forth. The code works some of the time but not all the time and I can't
figure out what's wrong. Can anyone help?
The following code is in a module and the buttons work OK
Option Explicit
Public SDimScale As Single
' ROMAN-D code
Public Sub SetFontRomanD()
Dim objTextStyle As AcadTextStyle
Set objTextStyle = ThisDrawing.TextStyles("standard")
objTextStyle.fontFile = "romand.shx"
SDimScale = ThisDrawing.GetVariable("dimscale")
objTextStyle.Height = SDimScale * 0.1875 'set the font to a
height of 3/16"
End Sub
' ROMAN-S code
Public Sub SetFontRomanS()
objTextStyle.fontFile = "romans.shx"
objTextStyle.Height = SDimScale * 0.09375 'set the font to a
height of 3/32"
End Sub
TIA
DonB
Replies (12)
Message 2 of 13
It seemed to work for me. New text objects came in at the 2 different sizes
and styles. Existing text with "Standard" style changed appearance but not
size.
I added "ThisDrawing.Regen acAllViewports" as the last line in the subs so
I could see changes right away.
When it's not working, what specifically does it do or not do?
James
Message 3 of 13
OK let me try to explain. Normally the text in the drawing is RomanS at
3/32" height but when we label a VIEW as an example the text is supposed to
be RomanD at 3/16" height. I would then switch back to RomanS at 3/32. The
text at RomanD doesn't seem to "STICK". I'll come back to the drawing later
and the RomanD text is 3/16" high but is then RomanS.
I would like the text to stay at 3/16" RomanD and the small text to stay at
3/32" RomanS
TIA
Don
"DonB" wrote in message
news:48407A5698F9FA80228A4C65460FF230@in.WebX.maYIadrTaRb...
these
can't
> Option Explicit
> ' ROMAN-D code
a
> height of 3/16"
> End Sub
> ' ROMAN-S code
a
> height of 3/32"
> End Sub
> TIA
> DonB
Message 4 of 13
I'm not too great with TextStyles, but instead of changing the fontFile of
"Standard", do you want two TextStyles ("D" and "S") that always point to
the same FontFiles. Then your macro would activate one or the other text
style?
Do you want to affect existing text Objects when you change, or just have
the new settings apply to text objects you subsequently create?
James
Message 5 of 13
Hi James
I only want to have the settings apply to text that I will be entering and
not anything that has been entered previously, when I change back to the
default which would be RomanS at 3/32" all the text I then enter should be
"S" at 3/32" until I switch back to "D" style again. I do not want to affect
any text already entered in the drawing.
TIA
DonB
"James Belshan" wrote in message
news:132E621BBE9590E0FD2F4F76248685ED@in.WebX.maYIadrTaRb...
> style?
> James
Message 6 of 13
> The co. I work for basically uses these 2 fonts in their drawings ...
Don,
It would be good to know what manual method is used to switch between the
fonts. If I use the "style" command in ACAD to change the font name from
romand to romans.shx, all the text objects that have "Standard" style change
font. So does your company have separate styles defined for the two fonts?
Or is all text "Standard"?
After playing around some more with text, it seems to me like the best way
to get 2 different fonts to "stick" is to have 2 styles called romanD and
romanS, and have your macros set one or the other style as active...
Message 7 of 13
OK James Thanks for the help.
I did try setting a D and an S style but that didn't seem to help either.
Oh well! I'll keep on trying.
Regards
DonB
Message 8 of 13
Sub ToggleActiveTextStyle()
Dim SDimScale As Double
' if styles already exist, .Add just selects them
With ThisDrawing.TextStyles.Add("romanS")
.fontFile = "romanS.shx"
End With
With ThisDrawing.TextStyles.Add("romanD")
.fontFile = "romanD.shx"
End With
If ThisDrawing.ActiveTextStyle.Name = "romanS" Then
MsgBox "Changing to D"
ThisDrawing.TextStyles("romanD").Height = SDimScale * 0.1875
ThisDrawing.ActiveTextStyle = ThisDrawing.TextStyles("romanD")
Else
MsgBox "Changing to S"
ThisDrawing.TextStyles("romanS").Height = SDimScale * 0.09375
ThisDrawing.ActiveTextStyle = ThisDrawing.TextStyles("romanS")
End Sub
Message 9 of 13
this code (previous post) seems to work for me. As I toggle back and
forth, and create text, the old text never changes its height or font. One
consideration would be whether you care if you have different text styles.
To me it doesn't seem like that big of a deal, after seeing more about how
they work.
Some stuff I learned about Text styles...
1 - changing the font file of a text style automatically changes the display
font of all text that uses the style.
2 - changing the height of a text style does not change the height of
existing text that uses the style.
2a - however, changing the style of a text entity (in the Properties window)
causes its height to change to that of the style.
about #1, this is why it seems like your company must already be using
multiple text styles in order to make different fonts.
Good luck,
James
Message 10 of 13
James
Thanks a lot for your work on this and your help is certainly appreciated.
The trouble with where I work is that the "Standard" is loosely controlled
with everyone getting there by their own method. But you're supposed to
follow it in your drawings.
I will try out your code and report back.
Best Regards
DonB
Message 11 of 13
Hello again James
Well I tried your code but I can't get it to work. It seems to get stuck on
RomanS and won't change from that. When I get a chance I'll play around with
it some more. Thanks for all your help in trying to resolve this problem.
Regards
DonB
these
can't
> Option Explicit
> ' ROMAN-D code
a
> height of 3/16"
> End Sub
> ' ROMAN-S code
a
> height of 3/32"
> End Sub
> TIA
> DonB
Message 12 of 13
That shouldn't happen if you open a new DWG and run the code.
If you're running it in an existing dwg, the only reason I can think that
this might happen is that it already has style "romanS" in it, but with a
different case (i.e. ROMANs)
So, you could try making your IF-THEN case insensitive:
Msgbox "The active style is " & ThisDrawing.ActiveTextStyle.Name
If lcase$(ThisDrawing.ActiveTextStyle.Name) = "romans" Then
Good luck,
James
Message 13 of 13
OK James
I'll try that. I didn't know that I had to worry about the case. I'll let
you know.
Don
news:208446B9C42363B5C2E080C2D22B06C5@in.WebX.maYIadrTaRb...
> Good luck,
> James
