2D section into 3D
2D section into 3D
2D section into 3D
Hi have a bunch of geological sections to convert from 2D into 3D,
all the sections are z=0
the X needs to be thansfered to Y, and Y to Z.
And I would need to input the actual X.
Can someone help with that, what would be the best approach, create a UCS,
then Wblock, or move-rotate all objects.
I have 168 files, speed would also be an important factor here.
Thanks.
To me it sounds simplest to Rotate3D the sections and then move them, rather
than messing with a UCS.
1) rotate positive 90 degrees around Z-axis vector (0,0,1)
2) rotate positive 90 degrees around Y-axis vector (0,1,0)
3) Move by vetor (X, 0, 0)
Could your program determine the X value by itself? You must have some way
of knowing which X to use for each section, so maybe the program can use the
same information and logic?
and yes I will be able to get the X, the x is in the file name.
I will need to mess with UCS anyways, if I want to import things in the
future on those section.
"James Belshan" a écrit dans le message de news:
8ED4F013F862236E36BF412FA5BD94BD@in.WebX.maYIadrTaRb...
rather
way
the
