Help with Selection set in VB
Message 1 of 10
Ok, here is the story, I have copied this piece of code from this same forum & I’m using it in VB NOT VBA, (it works fine under AutoCAD VBA) for some odd reason some stuff won’t work. I have noted the things that aren’t working on the code. Thanks in advance for your help.
William
Dim SelSet As AcadSelectionSet
Dim FilterType(0 To 0) As Integer
Dim FilterData(0 To 0) As Object
Dim blk As AcadEntity
AcadDoc.SelectionSets.Add("SelSet")
*-*-*-* ‘I GET THE SQUIGLEE LINES HERE-*-*-*-*
SelSet = AcadDoc.SelectionSets("SelSet")
SelSet.Clear()
FilterType(0) = 0
FilterData(0) = "INSERT"
*-*-*-* ‘I GET AN INVALID FILTERTYP OR FILTERDATA -*-*-*-*
SelSet.Select(AcSelect.acSelectionSetAll, , , FilterType, FilterData)
'SelSet.SelectOnScreen(FilterType, FilterData)
If SelSet.Count = 0 Then Exit Sub
For Each blk In SelSet
MsgBox(blk.ObjectName)
Next
Replies (9)
Message 2 of 10
FilterData(0 to 0) must be Variant, not Object
These could be all sorts of things, but I don't think an Object would ever
be an appropriate value. Could be a layer name (string), any type of
numeric value, etc.
If you're having trouble understanding that part and you're not familiar
with DXF format, you may want to browse through the DXF Reference section,
particularly the Entities section. It would probably help in understanding
how the FilterType/FilterData arrays actually work.
wrote in message news:[email protected]...
& I'm using it in VB NOT VBA, (it works fine under AutoCAD VBA) for some odd
reason some stuff won't work. I have noted the things that aren't working on
William
Message 3 of 10
Tom, VB does not have a Variant type. The Object, in this case, is
correct.....
"TomD" wrote in message
numeric value, etc.
William
Message 4 of 10
You beat me to it. VB Express got rid of a Variant type and replaced it with an Object.
Message 5 of 10
I'm going to guess that since you said "SQUIGLEE" you're not in VB or VBA
but rather VB.NET?
Sounds like your AcadDoc object is not instantiated.
William
*-*-*-* 'I GET THE SQUIGLEE LINES HERE-*-*-*-*
SelSet.Clear()
FilterType(0) = 0
*-*-*-* 'I GET AN INVALID FILTERTYP OR FILTERDATA -*-*-*-*
FilterData)
Next
Message 6 of 10
Thank you both and my sincerest apologies for the misleading answer.
.....Maybe I should be looking into VB Express?
an Object.
Message 7 of 10
Here is the first part of the code that was not included in the origina post.
Dim acadApp As AcadApplication
Dim AcadDoc As AcadDocument
Dim AcadObj As AcadObject
Dim BlockRef As AcadBlockReference
Try
acadApp = GetObject(, "AutoCAD.Application")
Catch
acadApp = CreateObject("AutoCAD.Application")
End Try
AcadDoc = acadApp.ActiveDocument
Message 8 of 10
In VB.Net the Integer is now a 32 bit integer where Acad is expecting a 16
bit integer.....try this:
Dim FilterType(0) As Int16
post.
Try
Catch
End Try
Message 9 of 10
Also, you could use Short in lieu of Int16...
"Jeff Mishler" wrote in message
Message 10 of 10
Thanks Jeff & others for the suggestions. Your solution fixed the problem. "Int16"
