Help with List Box Headings
Message 1 of 13
Could someone please help?
I have a list box with 4 columns and the headings property set to true.
When I run my program, the headings show up but are empty.
I would like the put some heading titles and cant figure out how.
The help for this process is of little help and reads:
When the system uses the first row of data items as column headings, they
can't be selected.
I can't figure out how to use the first row of data items as column
headings.
Thanks in advance,
Jeff
Replies (12)
Message 2 of 13
A list box or a grid?
"Jeff" wrote in message
news:852f21$9o325@adesknews2.autodesk.com...
> can't be selected.
> headings.
> Thanks in advance,
> Jeff
Message 3 of 13
Thanks for responding Frank,
It's a list box.
Jeff
Frank Oquendo wrote in message <852fl7$9o326@adesknews2.autodesk.com>...
Message 4 of 13
Jeff,
Check out the help files for the textcolumn property. I think that's
what your looking for.
-Josh
> It's a list box.
> Thanks
> Jeff
Message 5 of 13
You may be misunderstanding the use of columns in a list box. Columns cause
a list box to scroll horizontally as opposed to vertically. If you want
columns that you can enter specific items into (like a record in a
database), use a grid instead.
news:8532so$bq449@adesknews2.autodesk.com...
> Josh,
> Thanks for the help, but the textcolumn sets the active column to read
from.
> I want to give the headings a name.
> Thanks
> Jeff
> Minkwitz Design wrote in message <3874E628.AFA64232@xta.com>...
> >Jeff,
> >-Josh
Message 6 of 13
Josh,
Thanks for the help, but the textcolumn sets the active column to read from.
Jeff
>Jeff,
>-Josh
Message 7 of 13
Frank,
Thanks again!
You may be right that I am misunderstanding the use of columns.
I'm not sure how to use a grid control. I didn't think there is one.
I'm new to programming with vba.
Here is a sample of the code I'm using:
Private Sub UserForm_Initialize()
ListBox1.ColumnCount = 3
ListBox1.ColumnHeads = True
ListBox1.AddItem "Row 1, Col 1"
ListBox1.List(0, 1) = "Row 1, Col 2"
ListBox1.List(0, 2) = "Row 1, Col 3"
ListBox1.AddItem "Row 2, Col 1"
ListBox1.List(1, 1) = "Row 2, Col 2"
ListBox1.List(1, 2) = "Row 2, Col 3"
ListBox1.AddItem "Row 3, Col 1"
ListBox1.List(2, 1) = "Row 3, Col 2"
ListBox1.List(2, 2) = "Row 3, Col 3"
End Sub
Frank Oquendo wrote in message <8533ci$dr91@adesknews2.autodesk.com>...
Message 8 of 13
I must have missed the VBA part. You are correct, there is no grid available
in stock VBA.
news:8534ab$drd5@adesknews2.autodesk.com...
> Frank,
> Thanks again!
> End Sub
cause
Message 9 of 13
Jeff - Have yuo considered using a LISTVIEW in report mode instead?
Jeff wrote:
> Frank,
> Thanks again!
> End Sub
/* Tony Tanzillo Design Automation Consulting */
/* Programming & Customization for AutoCAD & Compatibles */
/* tony.tanzillo@worldnet.att.net */
/* http://ourworld.compuserve.com/homepages/tonyt */
Message 10 of 13
Tony,
I don't understand you mean.
Jeff
Tony Tanzillo wrote in message <38751E0F.79A41900@worldnet.att.net>...
>Jeff wrote:
>> Frank,
>> Thanks again!
>> End Sub
Message 11 of 13
He's referring to yet another control that is not present in the VBA
toolbox. Right click on your toolbox and select 'Additional Controls'. In
the resulting listbox, find and select the Microsoft Listview Control. Add
one to your form and use its properties to set up your columns. Refer to the
online help for more details
news:854mos$g4v3@adesknews2.autodesk.com...
> Tony,
> Jeff
Message 12 of 13
Frank,
Thank you very much for your help and patients. I think the Listview
Control is exactly what I need and more, Much more. With some of the other
properties of this control, I think I'll save several lines of code in other
areas of my program.
The one last question I have is how do you find help online for this item. I
looked at both Microsoft Visual Basic Site and Autodesk Web Site.
Thanks again,
Jeff
Frank Oquendo wrote in message <8551vj$g4s27@adesknews2.autodesk.com>...
the
Message 13 of 13
Typically, you can select the actual control on your UserForm and press F1.
Also, be sure to use the Object Explorer extensively. Press F2.
Jeff wrote in message
news:857gev$mt52@adesknews2.autodesk.com...
> Frank,
other
I
> Thanks again,
> Jeff
