The best way to handle this issue is through class module that will help you in organizing your program very effectively.
First step is class module. Here you define your all properties to be used. Also, here you will arrive at the calculated values like D in your code. The draw method in this class module does all heavy lifting for you.
Class Module Code
In this code I have converted angle 60° in your drawing as a variable. This will add flexibility of setting any angle desired.
Option Explicit
Private pi As Double
Private mRadius1 As Double
Private mRadius2 As Double
Private mAngle As Double
Private mSlotCount As Integer
Private mLocation As Variant
Private mStartAngle As Double
Private mConeHeight As Double
Private mComponentHeight As Double
Private mCompThickness As Double
Public Property Let Radius1(pRadius1 As Double)
mRadius1 = pRadius1
CalcCompThk
End Property
Public Property Get Radius1() As Double
Radius1 = mRadius1
End Property
Public Property Let Radius2(pRadius2 As Double)
mRadius2 = pRadius2
CalcMainConeHeight
CalcCompHeight
CalcCompThk
End Property
Public Property Get Radius2() As Double
Radius2 = mRadius2
End Property
Public Property Let Angle(pAngle As Double)
mAngle = pAngle
CalcMainConeHeight
End Property
Public Property Get Angle() As Double
Angle = mAngle
End Property
Public Property Let SlotCount(pSlotCount As Integer)
mSlotCount = pSlotCount
End Property
Public Property Get SlotCount() As Integer
SlotCount = mSlotCount
End Property
Public Property Let Location(pLocation As Variant)
mLocation = pLocation
End Property
Public Property Get Location() As Variant
Location = mLocation
End Property
Public Property Let StartAngle(pStartAngle As Double)
mStartAngle = pStartAngle
End Property
Public Property Get StartAngle() As Double
StartAngle = mStartAngle
End Property
Public Property Get ConeHeight() As Double
ConeHeight = mConeHeight
End Property
Public Sub Draw()
Dim cone1 As Acad3DSolid
Dim cone2 As Acad3DSolid
Dim cone3 As Acad3DSolid
Dim cyl As Acad3DSolid
Dim box As Acad3DSolid
Dim tempLoc(0 To 2) As Double
tempLoc(0) = mLocation(0)
tempLoc(1) = mLocation(1)
tempLoc(2) = mLocation(2) + mConeHeight / 2
Set cone1 = ThisDrawing.ModelSpace.AddCone(tempLoc, mRadius2, mConeHeight)
Dim tempConeHeight As Double
tempConeHeight = mConeHeight - mComponentHeight
tempLoc(2) = mLocation(2) + mComponentHeight + tempConeHeight / 2
Set cone2 = ThisDrawing.ModelSpace.AddCone(tempLoc, mRadius2 * (1 - Tan(pi / 2 - mAngle) / 2), tempConeHeight)
cone1.Boolean acSubtraction, cone2
Dim tempX As Double
tempX = mCompThickness / Tan(mAngle / 2)
tempConeHeight = (mRadius2 - tempX) * Tan(mAngle)
tempLoc(2) = mLocation(2) + mCompThickness + tempConeHeight / 2
Set cone3 = ThisDrawing.ModelSpace.AddCone(tempLoc, mRadius2 - tempX, tempConeHeight)
cone1.Boolean acSubtraction, cone3
tempLoc(2) = mLocation(2) + mCompThickness / 2
Set cyl = ThisDrawing.ModelSpace.AddCylinder(tempLoc, mRadius1, mCompThickness)
cone1.Boolean acSubtraction, cyl
Dim i As Integer
Dim inclAngle As Double
inclAngle = 2 * pi / mSlotCount
tempLoc(2) = mCompThickness + (mComponentHeight - mCompThickness) / 2
For i = 1 To mSlotCount / 2
Set box = ThisDrawing.ModelSpace.AddBox(tempLoc, 2 * mRadius2, mCompThickness, mComponentHeight - mCompThickness)
box.Rotate mLocation, mStartAngle + (i - 1) * inclAngle
cone1.Boolean acSubtraction, box
Next i
cone1.Update
Set cone1 = Nothing
Set cone2 = Nothing
Set cone3 = Nothing
Set cyl = Nothing
Set box = Nothing
End Sub
Private Sub Class_Initialize()
pi = 4 * Atn(1)
mRadius1 = 100
mRadius2 = 300
mSlotCount = 8
mAngle = pi / 3
mStartAngle = 0
CalcMainConeHeight
CalcCompHeight
CalcCompThk
End Sub
Private Sub CalcMainConeHeight()
mConeHeight = mRadius2 * Tan(mAngle)
End Sub
Private Sub CalcCompHeight()
mComponentHeight = mRadius2 / 2
End Sub
Private Sub CalcCompThk()
mCompThickness = (mRadius2 - mRadius1) / 4
End Sub
Second step is to use this class in your regular function. Here is the code that uses the class module defined above.
Calling Function
Option Explicit
Public Function DrawPart()
Dim pi As Double
Dim Radius1 As Double
Dim Radius2 As Double
Dim Angle As Double
Dim SlotCount As Integer
Dim StartAngle As Double
Dim loc(0 To 2) As Double
pi = 4 * Atn(1)
Dim myPart As clsComponent
Set myPart = New clsComponent
With myPart
loc(0) = 1000
loc(1) = 2000
loc(2) = 0
.Radius1 = 100
.Radius2 = 400
.Angle = 60 * pi / 180
.SlotCount = 10
.Location = loc
.StartAngle = 0
.Draw
End With
Set myPart = Nothing
End Function
I am sure, you will like this.
Nimish
PS: I will document the geometric calculations for your ready reference as I get time in the future.
