help needed to debug this VBA program
Message 1 of 10
Hi All,
I am new to VBA and I have been stuck wid this.Can someone please help.
Public Function GetArray(ByRef pFileArray As Variant) As Boolean
Me.Show
For Each i In sFileArray
pFileArray(i) = sFileArray(i + 1) 'assigning the values in sFileArray to pFileArray
Next
GetArray = mbool
End Function
At the loop it says that i is not initialized.Before the 'For' ...The Me.Show navigates to the form and takes all the input I need.when it comes back it does not recognize variable i.
Can u please tell me how to make that function recognize 'i'
Any help will be appreciated.
Avantika
Replies (9)
Message 2 of 10
typically you would use something like
For i = 0 to
Next i
wrote in message news:5210809@discussion.autodesk.com...
Hi All,
Me.Show
pFileArray
Next
GetArray = mbool
End Function
Avantika
Message 3 of 10
don't you need this..
dim i as interger
right at the start????
Message 4 of 10
For i = Lbound(sFileArray) to Ubound(sFileArray)-1
Next i
Saludos, Ing. Jorge Jimenez, SICAD S.A., Costa Rica
Hi All,
Me.Show
pFileArray
Next
GetArray = mbool
End Function
Avantika
Message 5 of 10
It depends on whther they have the option Explicit at the top of the mdule.
"C Witt" wrote in message
news:5211397@discussion.autodesk.com...
dim i as interger
Message 6 of 10
"It depends on whther they have the option Explicit at the top of the
module."
yea, and that is what i think he has.. (given his original comment of
vba not recognizing the "i" variable)
Message 7 of 10
I believe "i" should be declared as a Variant
or the For Each statement will fail when used
on an array.
news:5212234@discussion.autodesk.com...
module."
Message 8 of 10
what for each? per your example post
Next i
i could be an integer or long wo problem but i dont use variant for index
value.
"Jorge Jimenez" wrote in message
news:5212614@discussion.autodesk.com...
on an array.
module."
Message 9 of 10
Sorry, I was reffering to the OP's problem
and sample code he posted.
What I posted was another way of doing it
but if he wants to use a For Each on an array
he must declare the variable as a Variant
"Ben Stone" wrote in message
news:5212874@discussion.autodesk.com...
Next i
value.
on an array.
module."
Message 10 of 10
sorry didnt see the other post you made, ok yes thats true
news:5212882@discussion.autodesk.com...
Next i
value.
on an array.
module."
