Help me start in objectarx, please?
I'm begging for a handout here. I want to start using ObjectARX but need
help taking the first step.
Can someone please post some basic code simply showing how to open and get
into the database of an axdbdocument? Code doesn't have to do anything, just
show me how to make initial access. I think I can take it from there (famous
last words).
Thanks in advance.
Ed__Jobe
Tony, you mean ObjectDbx. ObjectArx is a set of library for C++. ObjectDbx is an ActiveX interface. Look at my post in Customer Files called "ImportPageSetupsND" for an example. -Ed
Ed
How to post your code.
Oops. I kew that. Guess I need more help than I
thought. I retrieved your file and it works.
That was the jump start I needed. Thank you, thank
you, thank you.
Tony,
ed,
i to am just starting ObjectDBX and found you post
on the customer files.... however, for some reason the code stops at
'dbxdoc.open strfilepath'  with a VBA error message of 'method 'OPEN' of
object 'IAxDbDocument' failed'.....  i assume that i haven't registered
something... however i have made a reference to the ObjectDBX 1.0 Type Library
and i have registered the AxDb15.dll as mentioned in the comments.... is there
something else i am missing???
cheers
mark
Tony,
Ed__Jobe
When it breaks, go to debug and check to see if you got the filename right. Also, did you try to open a dwt? You can only open dwg's. -Ed
Ed
thanks ed.... i figured it out it was a typing
error
When
-Ed
