Having a VBA menu return after use
I want some advice on how to have a menu created in vba return after its major function has been run.
As shown below, I have a menu I created in vba and when the create button is pressed, the user defines at what point in the drawing that the resulting second figure should be placed.
menu.PNGMenu I start and want to return to
Result_of_menu.PNGResult of hitting the create button
At the end of this, I would like to return to the original menu as I am forced to hide it once the button is pressed in order for the user to place the object down.
However, I cannot, as of now, seem to just show the menu at the end of the button-click function because I would like to have the object placed and shown as above before the user places a different object. show.PNG
Can I have some help?
Ed__Jobe
Can you set the forms ShowModal property to true? Then you won't have to hide it. You'll need to add a close button to cancel the form.
Ed
How to post your code.
Hello again,
Ed's idea seemed to work and I did some research on what ShowModal meant here and even though it is for excel, it still helped a lot.
https://wellsr.com/vba/2016/excel/showmodal-vba-vbmodal-and-vbmodeless/
Here is how I edited the code for what I wanted it to do:
In a menu above that opens this menu, I ran the following code.
That now shows this edited menu
The code is run as follows below: if the repeat button is clicked, it remains modeless
if the finish button is clicked, it hides the menu
Ed__Jobe
When you finish with the form, you don't want to simply hide it as it will still be in memory. Follow up your code with:
Unload Me
Either that or create a Close button with its only code is Unload Me. That way a user can also, leave without adding entities. i.e. cancelling the dialog.
Ed
