Global Modules in VBA?
i am new to vba. is it possible to call a subroutine in a vba project from
an entirely different vba project? (or do you need to create a
DLL/ActiveX?). if it is possible, how do you do it?
thanks,
sc
Mid-State Consultants
[email protected]
yes you can.
first you have to load the other project into memory and the call the sub
from your original like:
!otherproject.othersub
JPMC
Steve Carter escribió en mensaje ...
>thanks,
>sc
>[email protected]
i am doing something wrong. i receive the following microsoft vb error.
Compile error:
Invalid or unqualified reference
the project is loaded in memory. the project name is link.dvb, the module
is called LinkModule, and the subroutine is called get_login_name.
in my calling subroutine i did the following (per your instructions):
!link.get_login_name
any ideas?
thanks,
sc
[email protected]
"juan pablo" wrote in message
news:[email protected]...
> yes you can.
> JPMC
from
> >thanks,
> >sc
> >[email protected]
The name of the DVB containing the module you want to access must be listed
to the left of the exclamation: MyOtherProject!link.get_login_name.
BTW, assuming get_login_name does what its name says, why not just use
ThisDrawing.GetVariable("LOGINNAME")?
http://www.acadx.com
All use of the contents of this article is subject to the
terms and conditions at http://www.acadx.com/csc.htm
"Steve Carter" wrote in message
> Compile error:
> any ideas?
> thanks,
> sc
> [email protected]
Steve's message was moved to the Customer Files group since it
included a 2.875 meg file. Here is just his message.
Anne Brown
Manager, Moderator
Autodesk Product Support discussion groups
Discussion Q&A: http://www.autodesk.com/discussion
Subject:
Re: Global Modules in VBA?
Date:
Tue, 21 Nov 2000 07:43:23 -0800
"Steve Carter"
Newsgroups:
autodesk.autocad.customization.vba
i'm really starting to feel stupid. i have attempted to do what
you
explained without success.
i receive the following microsoft VB error:
Compiler error:
Variable not defined
i have attached a screen shot of the vba subroutine showing the
subroutine
(code) that i want to call, also the project explorer (showing
the module
and project).
in answer to your question, the login refers to logging into a
particular
database, not AutoCAD (or network).
thanks for the help,
sc
[email protected]
it appears to be working. thanks for the great assistance, you are very
helpful.
thanks,
sc
[email protected]
"Frank Oquendo" wrote in message
> Don't get discouraged. In no time, you'll be knocking these projects out
> without breaking a sweat. Here's something you might want to look into:
with
> both projects loaded in the ide, add a reference to the project you want
to
> call to the project you want to call it from. IOW, add a reference to
> Linking in your other project.
> Now where you want to use code from the Linking project, type Linking.
> (include the dot). An IntelliSense list will pop down listing all the
public
> routines in that project. One thing: I do not know if the Linking project
> will be demand loaded or if you have to load prior to calling it. Joe
> Sutphin might be a good guy to ask. Hope this helps.
> > i'm really starting to feel stupid. i have attempted to do what you
> > Compiler error:
subroutine
> > (code) that i want to call, also the project explorer (showing the
module
> > and project).
particular
Frank,
I am unsure if my e-mails got out, i was getting a rejection notice on my
side. You are very kind to offer assistance. I will call on you, but only
when I truly need help.
Thanks again,
sc
[email protected]
with
to
public
> > Compiler error:
subroutine
module
> > and project).
particular
