Getting value
Getting value
Getting value
Hi all,
I am storing value by lisp as (SETQ A "x"). How i can recall the value of "x" in VBA.
Thanks in advance.
Use one of the system variables such as Users1, (setvar "users1" x) then in
VBA you use the getvar method to retrieve it.
Murph
wrote in message news:5080283@discussion.autodesk.com...
Hi all,
"x" in VBA.
Thanks in advance.
You can also access it via the VL.Application and/or the VLAX.cls posted in
this group.
(I have not used either, only dabbled with them a few times, so I can't
provide an example.)
"Murph" wrote in message
news:5080378@discussion.autodesk.com...
Murph
Hi all,
"x" in VBA.
Thanks in advance.
Thanks for your reply,
I am experimented to get a value in VBA by using SETVAR and GETVAR command like (setvar "users1" x). its not work.
See my Codes, am set a value in VBA as
ThisDrawing.SendCommand "(setq userid 1) " & vbCr.
Just i want to recall the userid value in VBA.
any other idea.
Dim i As Integer
i = ThisDrawing.GetVariable("Useri1")
ThisDrawing.SetVariable "Useri1", 2
Now its OK
Thanks for all
