getentity
getentity
getentity
I'm trying to get an entity handle with the Utility.getentity method,
however I get a "syntax error". The other "gets" work fine. I think I've
copied the code from the example correctly.
loAcadDwg=loAcadApp.activedocument
loAcadUtility=loAcadDwg.utility
loAcadUtility.GetEntity loBubble,basepoint,"get it"
I guess there are other ways to accomplish my task but thought I would try
this. Any ideas? Thanks
Dan Aldridge
On Wed, 23 May 2001 07:29:10 -0700, "Dan Aldridge"
wrote:
»I'm trying to get an entity handle with the Utility.getentity method,
»however I get a "syntax error". The other "gets" work fine. I think I've
»copied the code from the example correctly.
»loAcadDwg=loAcadApp.activedocument
»loAcadUtility=loAcadDwg.utility
»loAcadUtility.GetEntity loBubble,basepoint,"get it"
You're missing "Set" from each of the assignments but I would expect
"Object variable or With block variable not set". Which line gives
you the "syntax error"?
Paul Marshall
pmarshal@vulcraft-al.com
Paul,
I'm still having trouble with the getentity method. I forgot to mention
that I am using Visual Foxpro. Sorry. Although I have not had any problems
accessing the Acad Object Model to date it could be an issue in this case.
Thanks again for your comments.
Dan Aldridge
"Paul Marshall" wrote in message
news:6hkngt40un3qbhnc5gomkapvlpq7i0vdu0@4ax.com...
> Paul Marshall
Public Sub GetEntityHandle()
Dim objAcadEntity As AcadEntity
Dim varPoint As Variant
'there is no error checking in this routine
ThisDrawing.Utility.GetEntity objAcadEntity, varPoint, "Select an entity"
MsgBox objAcadEntity.Handle
End Sub
Find out more about the NEW "AutoCAD Visual Basic Programmers Reference" -
the ultimate guide to Visual Basic programming for R14/2000/2000i and 2002
mailto:omnisource@worldnet.att.net?subject=NewVBTitle
Joe Sutphin
Author of "AutoCAD 2000 VBA Programmers Reference"
ISBN #1861002564
"Dan Aldridge" wrote in message
news:82697C48DF37166A55A7FBC4452C001F@in.WebX.maYIadrTaRb...
> Paul,
problems
> Dan Aldridge
I've
> > Paul Marshall
