Message 1 of 14
10:08 AM
Hello All,
I'm writing a script to mirror a line off of an arc. I'm having troubles finding a way to automatically identify a mirror line, (presumably one that would go from the arc's edge to its center point). The way the code works right now is that a user must select the center point to define the line over which the line will be mirrored.
Sub PLINEMIRROR() Dim rayLine As AcadLWPolyline Dim perpLine As AcadLWPolyline Dim Points(0 To 3) As Double Dim pt1 As Variant Dim pt2 As Variant Dim mirrorObj As AcadLWPolyline 'Allows user to define ray points pt1 = ThisDrawing.Utility.GetPoint(, "Pick Point to Begin Line:") pt2 = ThisDrawing.Utility.GetPoint(pt1, "Pick Trace Start Point:") 'Stores pt Variant values to Points Double values. Points(0) = pt1(0) Points(1) = pt1(1) Points(2) = pt2(0) Points(3) = pt2(1) 'Creates PLine object "rayLine" Set rayLine = ThisDrawing.ModelSpace.AddLightWeightPolyline(Points) focCtr = ThisDrawing.Utility.GetPoint(, "Choose Focal Center of Curve") Set mirrorObj = rayLine.Mirror(pt2, focCtr) End Sub
Essentially what I want to happen is for focCtr to be found automatically upon selection of pt2.
I've been playing around with some solutions that I've found on other forums, but have had no luck. The most promising piece of code that I've found is this:
Sub ss() Dim ss As AcadSelectionSet Dim obj As AcadObject Dim oArc As AcadArc Set ss = ThisDrawing.SelectionSets.Add("ss1") ss.SelectOnScreen For Each obj In ss If TypeOf obj Is AcadArc Then Set oArc = obj Debug.Print oLine.StartPoint(0) End If Next ss.Delete End Sub
However, the AcadArc object doesn't have a GetCenter property like the AcadCircle object.
