Get polyline entities crash from BlockReference in release mode
Hi
I am using the realdwg sdk, i found a problem with getting polyline entities inside a new BlockReference
So if it's the block from the model space, it's like this
BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
BlockTableRecord blockrecord = (BlockTableRecord)tr.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForRead);
Then i can iterate all the entities to get the polyline like this
void getPolyline(BlockTableRecord bt, Transaction tr) {
    foreach (ObjectId id in bt)
        Entity ent = (Entity)tr.GetObject(id, OpenMode.ForRead);
         if (ent is Polyline) {
                getDATA((Polyline)ent)
         if (ent is BlockReference) {
              //recursive calling
             getPolyline((BlockReference)ent, tr)
void getDATA(Polyline p) {
    for (int i = 0; i < p.NumberOfVertices; i++)
        SegmentType t = p.GetSegmentType(i);
        Console.WriteLine(t);
        if (t == SegmentType.Line)
                 LineSegment2d l = p.GetLineSegment2dAt(i);
                 //Save to my own data structure
         else if (t == SegmentType.Arc)
                CircularArc2d arc = p.GetArcSegment2dAt(i);
                //Save to my another data structure
The problem is that if the ent is another BlockReference; I get crash error.
Should I start a new Transaction for each new BlockReference?
If I just get the Polyline of first the BlockReference(The model space one), not calling the recursive function, it works fine without crash. If I call the recursive part. I can the error:
System.AccessViolationException was unhandled
Source=Acdbmgd
StackTrace:
 Autodesk.AutoCAD.DatabaseServices.Transaction.DeleteUnmanagedObject()
 Autodesk.AutoCAD.Runtime.DisposableWrapper.!DisposableWrapper()
 Autodesk.AutoCAD.Runtime.DisposableWrapper.Dispose(Boolean A_0)
 Autodesk.AutoCAD.Runtime.DisposableWrapper.Dispose()
What did I do wrong?
Thx
The file I use is attached
norman.yuan
Firstly, in spite this forum is called "Visual Basic Customization", "Visual Basic" is really meant for AutoCAD VBA for historical reason, and the discussion is focused on AutoCAD VBA and AutoCAD COM API. Since your code deals with AutoCAD .NET API, it would be better to post here.
Now regarding your code, it looks like you are confusing BlockTableRecord and BlockReference: the method
getPolyline(BlockTableRecord bt, ...)
takes a parameter of BlockTableRecord type. However, in your recursive calling the same method, you pass it a BlockReference type, thus the crash. BlockReference is just a REFERENCE to a BlockTableRecord. It DOES NOT contain any entity (except for AttributeReferences).
So, your code should always crash, regardless the code being debug mode or release mode.
Norman Yuan
Drive CAD With Code
@norman.yuan
Sorry post this in wrong place, I do have the code to fetch the block actually.
BlockReference br = (BlockReference)ent;
BlockTableRecord blockRecord = (BlockTableRecord)tr.GetObject(br.DynamicBlockTableRecord, OpenMode.ForRead);
// Then do the recursive part.
Sorry
