Get a list of macros in a module
Is it possible to get a list of procedures in a module.
I would like to provide a form that presents the User with a list of macros
similar to the macro dialog box in AutoCAD (ALT+F8)
Regards
Tom Roberts
__________________________
MechWest Design & Drafting
Perth, Western Australia
Sure, find a copy of my FREE macro recorder. That should get you started.
Joe
"Tom Roberts" wrote in message
news:4861347@discussion.autodesk.com...
Regards
Tom Roberts
Use these previous posts to show you an example of the proper reference and objects you would use to satisfy your request.
http://discussion.autodesk.com/thread.jspa?messageID=396801
http://discussion.autodesk.com/thread.jspa?messageID=431258
http://discussion.autodesk.com/thread.jspa?messageID=4243969
If these don't help post back, expain what you need or don't understand, and I'm sure someone will assit you with the code
Good luck,
Bob Coward
CADS, Inc
Joe
Where ?
Bernard Flavignard
"Joe Sutphin" a écrit dans le message de news:
4861555@discussion.autodesk.com...
Joe
Regards
Tom Roberts
Right here, I have attached it.
Joe
"Bernard Flavignard" wrote in message
news:4862576@discussion.autodesk.com...
Joe
Where ?
Bernard Flavignard
Joe
Regards
Tom Roberts
This function I wrote just outputs to the Immediate window, but you could
modify it to write to a dialog control.
Public Sub EnumCode()
'enumerate the procedures in a project
Dim objVB As VBE
Dim objComponents As VBComponents
Dim objComponent As VBComponent
Dim objCM As CodeModule
Dim cnt As Integer
Dim l As Long
Dim strLine As String
Dim strProc As String
Dim strProc1 As String
Set objVB = ThisDrawing.Application.VBE
Set objComponents = objVB.ActiveVBProject.VBComponents
For Each objComponent In objComponents
Set objCM = objComponent.CodeModule
Debug.Print objComponent.Name
cnt = objCM.CountOfLines
For l = 1 To cnt
strLine = objCM.Lines(l, 1)
strProc = objCM.ProcOfLine(l, vbext_pk_Proc)
'only print procedure line once per procedure
If strProc <> "" And strProc <> strProc1 Then
Debug.Print vbTab & strProc
strProc1 = strProc
End If
Next l
Next objComponent
End Sub
Ed
Regards
Tom Roberts
