Get 3D part length
Get 3D part length
Get 3D part length
Can someone please help me?
Attached is a 3D beam.
Is it possible to create a code (VBA) to get the length of this part?
For conferencing, the attached piece has a length of 948cm (you can use command dist to conference).
Attention: I need a code that takes the length of the automatic part without having to turn the part or click something. The end use is to take the length of a project full of 3D parts.
Thank you all.
Ed__Jobe
Custom 3D objects do not have a length property assigned as AutoCAD does not know what you would consider length, e.g. what two points define the length? There are several to choose from. You could attach some data to the object when you create it and then read that back.
Ed
How to post your code.
I need the distance shown below.
