For Each Layout In ThisDrawing.Layouts
shastu
Advisor Advisor
shastu
I created a VBA routine within autocad using the below statement:
This loops through each layout in the current drawing. When I try to take this code into straight VB6 it gives me a Run-time error 424, Object Required. I already have the Layout defined as "Dim Layout As AcadLayout" What else do I need to get this to run?
VB6 does not know what ThisDrawing is......
"shastu" wrote in message news:5869966@discussion.autodesk.com...
shastu
I realize that. That is why I am asking for help. What do I need to replace that with?
shastu
Never mind I got it. I needed to add the following lines
Set objAcadApp = GetObject(, "AutoCAD.Application")
Set objAcadDoc = objAcadApp.ActiveDocument
objAcadApp.Visible = True
Then I changed all the "ThisDrawing" to "obcAcadDoc" and it worked.
you didn't necessarily need to change your ThisDrawing declarations. you
could declared it in VB like
Dim ThisDrawing As AcadDocument
then everything works as is.
wrote in message news:5870058@discussion.autodesk.com...
shastu
Thanks for the tip
