Floating Userform on CAD screen
Dear all,
I want to create a userform floating on CAD screen.
I find a example but it's in excel vba. I know nothing about API or Class Module theory
Please help me change this code to use in Cad
Here my attached drawing embeded with code from Excel
http://www.cadviet.com/upfiles/2/modeless.dwg
Norman_Yuan
You can forget the code from Excel example.
The VBA implemented by AutoCAD has built-in way to show UserForm as either Modal or Modeless with Modal mode as default. Simply call
UserForm.Show or UserForm.Show vbModal to get a modal form shown
Or
UserForm.Show vbModeless to get a floating form shown
However, just showing UserForm as Modeless, you may not be able to do anything useful with the floating form, because the form does not hold focus. So, in order to use modeless form in Acad VBA, you need to use the form in conjuction with acFocusCtrlxx.dll (xx is Acad version number).
Norman Yuan
Drive CAD With Code
Edit the property of your User form, and change the "ShowModal" option to False
