Finding the End Vertex of a Polyline
Civil3DReminders_com
Mentor Mentor
How does one find the end vertex of a LWpolyline? I want to add a point at the beginning and end of a LWpolyline. The start is easy since it is 0, but can't seem to think of a way to find the end vertex easily.
Christopher
Civil Reminders
http://blog.civil3dreminders.com/
http://www.CivilReminders.com/
' Create the selection set
Set lo_SSet = ThisDrawing.SelectionSets.Add("SSET")
Set lo_SSetDims = ThisDrawing.SelectionSets.Add("SSETDIMS")
' Add entities to a selection set by prompting user to select on the
screen
ThisDrawing.Utility.Prompt vbCrLf & "Select Profile to process ..."
lo_SSet.SelectOnScreen
' Return Insertion point using a prompt
lo_Pnt = ThisDrawing.Utility.GetPoint(, "Pick Insertion point : ")
' Extract Vertices
Set lo_LWPline = lo_SSet.Item(0)
lv_Coords = lo_LWPline.Coordinates
dim LI_I as Integer
LI_I = ubound(lv_Coords )
Something like this.
Dale
"ChristopherF" wrote in message news:5789951@discussion.autodesk.com...
Christopher
Hi Chris,
An LWPolyline object has a property of Coordinates.
If you define a variant variable you can do this:
Sub AddToPolyline
Dim v as Variant
Dim i as Integer
Dim dCoords() as double
Dim oPoly as AcadLWPolyline
... Select the polyline in any suitable way
v = oPoly.Coordinates
redim dCoords(0 to Ubound(v) + 4) ' You need 4 more items - 2 at each
end to store the new points
' Add the new start
dCoords(0) = Xvalue of new start point
dCoords(1) = Yvalue of new start point
' Add the new end
dCoords(Ubound(dCoords) - 1) = Xvalue of new endpoint
dCoords(Ubound(dCoords)) = Yvalue of new end point
' Transfer the existing coordinates to the middle section of the polyline
for i = 0 to Ubound(v)
dCoords(i + 2) = v(i)
next i
oPoly.Coordinates = dCoords
oPoly.Update
End Sub
Laurie Comerford
Christopher
Thanks Laurie, didn't know about the UBound.
Here is the code I ended up with for anyone interested:
oAcadLWpolyline has already been found:
Dim dEndPoint As Variant
Dim v As Variant
Dim l As Long
v = oAcadLWpolyline.Coordinates
l = ((UBound(v) + 1) / 2) - 1
dEndPoint = oAcadLWpolyline.Coordinate(l)
Civil Reminders
jbooth
dim result as Variant
result = polyline.Coordinate (ubound(polyline.Coordinates) \ 2 - 1)
The \ operator is an integer based operator, and will automatically discard the remainder of the division for you.
ie: 7 / 5 = 1.4 (double) but 7 \ 5 = 1 (integer)
To add a vertex to the end of a polyline, call the AddVertex() method using the index you calculated (obviously).
