Hello world
Im trying to find the intersection of lines and blocks, but I need the accurate position. I found out the the intersectwith method returns the line and bounding box intersection point. my block is a circle and I need the exact position. by the way, its not just one circle, its a couple of circles with the same center but different radiuses.
here is the code:
Dim oblk As AcadBlock
Dim oBlk1 As AcadBlock
Dim oBlkRef As AcadBlockReference
Dim oBlkRef1 As AcadBlockReference
Dim oEnt As AcadEntity
Dim oEnt1 As AcadEntity
Dim SS As AcadSelectionSet
Dim BlockEnt As AcadEntity
For Each lineobj In LineSSet
For Each blockrefobj In BlockSSet
Set SS = BlockSSet
For Each oBlkRef In SS
Set oblk = ThisDrawing.Blocks(oBlkRef.Name)
For Each oEnt In oblk
If TypeOf oEnt Is AcadBlockReference Then
Set oBlkRef1 = oEnt
Set oBlk1 = ThisDrawing.Blocks(oBlkRef1.Name)
For Each oEnt1 In oBlk1
With oEnt1
If Not ThisDrawing.Layers(.Layer).Lock Then
.Layer = "0"
.color = acByLayer
End With
Next oEnt1
Else
intpoints = lineobj.IntersectWith(oEnt, acExtendNone) '////here is the problem
MsgBox intpoints(0) & " " & intpoints(1)
Next oEnt
Next oBlkRef
there is an intersection, but I get the subscript out of range error for the message box.
where is the problem?
