Finding Autocad
Finding Autocad
Message 1 of 10
Finding Autocad
I am looking for a way to locate the installation path for Autocad 2000. I
would prefer to do it without starting Autocad. I can get the registry value
but that value can vary depending on the product you run. For example, mine
reads as "Software\Autodesk\AutoCAD\R15.0\ACAD-8:409", but the portion that
reads "8:409" can be different for various installations. How can I
consistently get the "AcadLocation" key regardless of the product that was
installed. I tried using an AppPath("acad.exe") function but when I ran it
on a different machine, it found Release 14.
Replies (9)
Message 2 of 10
Every A2K installation will have a seperate key under
HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\R15.0. I can't comment on R14
since I do not have access to it but I suspect it would be similar. From
there, you can extract the AcadLocation.
Visit me at http://www2.stonemedia.com/franko
"Tim Nary" wrote in message
news:ef06a7b.-1@WebX.SaUCah8kaAW...
value
mine
that
Message 3 of 10
Exactly, but how can I get the key(s) that exists under "R15.0" (or all of
them) without knowing what the key name may be?
Message 4 of 10
I'm sure Randall Rath has some API trick up his sleeve. Personally, I use
RegObj.dll. I've attached it to this message. Copy it into your system
folder and register it. The start a VBA project, add a reference to the
"Registry Manipulation Classes" and paste in this code:
Public Sub ListAcadLocations()
Dim key As RegKey, subKey As RegKey
Set key =
RegKeyFromString("\HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\R15.0")
For Each subKey In key.SubKeys
Debug.Print subKey.Name
Debug.Print subKey.Values("AcadLocation").Value
Next
End Sub
news:ef06a7b.1@WebX.SaUCah8kaAW...
Message 5 of 10
Well, Frank beat me to it, but here's another solution. 🙂
I don't have A2K, so let me know if it works.
- Adam
Public Function Acad2KPath()
On Error Resume Next
Dim strClsId As String 'class ID for A2K
Dim strPath As String 'path returned from registry
Dim wsh As IWshRuntimeLibrary.IWshShell
Set wsh = CreateObject("Wscript.Shell") 'create windows scripting object
strClsId = wsh.RegRead("HKEY_CLASSES_ROOT\AutoCAD.Application.15\CLSID\")
'get the Class ID for A2K
strPath = wsh.RegRead("HKEY_CLASSES_ROOT\CLSID\" & strClsId &
"\LocalServer32\") 'get the automation path
If strPath <> "" Then 'make sure the key exists
strPath = VBA.Left$(strPath, Len(strPath) - 12) 'trim off "
/Automation"
If Dir(strPath) <> "" Then 'make sure the file exists
Acad2KPath = strPath 'set function value
Set wsh = Nothing
End Function
value
mine
that
Message 6 of 10
Thank you, I got it to work using the REGOBJ.dll
Message 7 of 10
Hi Tim,
Here is a simple vbscript file which will extract the Acad 2000 installation
path.
'create a instance of Wsript object
Set po_scr = CreateObject("Wscript.Shell")
ps_regval =
po_scr.regread("HKLM\Software\Autodesk\Autocad\R15.0\ACAD-1:409\AcadLocation
msgbox ps_regval
Remember this sample code extracts the installation path of vanilla AutoCAD
2000 only and not any other products like MDT, ADT, LDDT etc.
Cheers,
Thilak
Tim Nary wrote in message
news:ef06a7b.4@WebX.SaUCah8kaAW...
Message 8 of 10
Nice. But his point was that he may not know exactly which key to look for
as the key varies with the flavor of AutoCAD installed on the machine. For
example, your script will not allow him to locate an R14 installation or a
Mechanical Desktop 4 installation.
"Thilak" wrote in message
news:ef06a7b.5@WebX.SaUCah8kaAW...
> Hi Tim,
installation
> path.
> ps_regval =
> msgbox ps_regval
AutoCAD
> Cheers,
> Thilak
Message 9 of 10
You really don't have to go through all of that, you
can find the location of Acad.exe here:
HKEY_CLASSES_ROOT\AutoCAD.Drawing.15\protocol\StdFileEditing\server
> - Adam
> /Automation"
> End If
> End If
> Set wsh = Nothing
> End Function
> value
> mine
> that
/* Tony Tanzillo Design Automation Consulting */
/* Programming & Customization for AutoCAD & Compatibles */
/* tony.tanzillo@worldnet.att.net */
/* http://www.caddzone.com */
Message 10 of 10
"Tony Tanzillo" wrote in message
news:392081C9.585BB78E@worldnet.att.net...
My registry does not have that key for R14, but it sounds like it is there
for the A2K version. 🙂
Since I don't have A2K installed, I did all my testing with the R14 version,
and assumed that A2K would have the LocalServer32 key.
Thanks for the tip.
- Adam
Enum SystemInfo
Cad_Software = "AutoCAD 14.01"
VB_Product = "VBA / VB6"
Platform = "WinNT4 SP5"
End Enum
