ActiveX SetPlotWindow
I have posted a drawing to the customer files that illustrates a peculiar
problem I'm having. There is an embedded sub called
"getthedarnplotwindowright". It attempts to allow the user to specify a
plot window. Then it displays the preview. It also draws a line as a check
that the coordinates are correct. On certain drawings, the preview will not
calculate correctly, this is one. If you insert this drawing into a fresh
drawing, it will work correctly. My question is: What is it about this
drawing (and others) that is causing this malfunction?
thanks for your help,
-mjm
Hi Michael,
Check this out.
While using GetPoint method of AcadUtility object to obtain the points, you
must translate the coordinates to DCS (Display Coordinate System) before you
can use them in SetWindowToPlot method of Layout object.
GetPoint method (which allows you to pick a point on the screen) returns you
the picked point's 3D coordinates in WCS (i.e. World Coordinate System). So
you must translate the points from WCS to DCS before passing them to
SetWindowToPlot method. Please find below a sample code which highlights how
to achieve this.
For more details please refer the online help of AutoCAD VBA ActiveX and VBA
Developer's Guide->Chapter 8 -- Working in Three-Dimensional Space->
Converting Coordinates
Option Explicit
Sub f_plotWindow()
'paste this code in VBA of AutoCAD2000
'declare the required variables
Dim po_lay As AcadLayout
Dim p1 As Variant
Dim p2 As Variant
Set po_lay = ThisDrawing.ActiveLayout
'get two points
p1 = ThisDrawing.Utility.GetPoint(, "first point")
p2 = ThisDrawing.Utility.GetCorner(p1, "second point")
'translate the points which are in World UCS to Display coordinates
p1 = ThisDrawing.Utility.TranslateCoordinates(p1, acWorld, acDisplayDCS,
False)
p2 = ThisDrawing.Utility.TranslateCoordinates(p2, acWorld, acDisplayDCS,
False)
'change the variables from 3 element array to 2 element array
ReDim Preserve p1(0 To 1)
ReDim Preserve p2(0 To 1)
'reorder the points to lower left and upper right corner irrespective of
the way user selects the points
Call f_setCoord(p1, p2)
po_lay.SetWindowToPlot p1, p2
po_lay.PlotType = acWindow
ThisDrawing.Plot.DisplayPlotPreview acFullPreview
End Sub
Sub f_setCoord(p1 As Variant, p2 As Variant)
Dim pd_xMin As Double
Dim pd_yMax As Double
If p1(0) > p2(0) Then
pd_xMin = p2(0)
p2(0) = p1(0)
p1(0) = pd_xMin
If p1(1) > p2(1) Then
pd_yMax = p2(1)
p2(1) = p1(1)
p1(1) = pd_yMax
End Sub
Cheers,
Thilak
michael montagne wrote in message
news:ef06b16.-1@WebX.SaUCah8kaAW...
check
not
> -mjm
Hi Thilak,
Thanks a million! I spent several hours trying to solve the same problem
and had finally ended up using code to create a view and plot it with the
PlotView method! Thanks for the tip! 🙂
- Adam
P.S.
I modified the code to work in R14. Hope it can help someone else. 🙂
'Code by Thilak, modified for AutoCAD R14
Option Explicit
Sub f_plotWindow()
'paste this code in VBA of AutoCAD R14
Dim p1 As Variant
Dim p2 As Variant
Dim dblScale(0 To 1) As Double 'plot scale
'get two points
False)
False)
With ThisDrawing.Plot
.PlotScale = dblScale 'set scale to fit
.PlotWindow p1, p2 'set plot window
.PlotPreview acFullPreview 'show full preview
End With
End Sub
pd_xMin = p2(0)
p2(0) = p1(0)
p1(0) = pd_xMin
pd_yMax = p2(1)
p2(1) = p1(1)
p1(1) = pd_yMax
End Sub
Thilak,
You have my admiration and respect. I'm still confused about why some
drawings worked and some did not but using the displayDCS instead of UCS
seems to work under all circumstances so I guess it doesn't matter so much.
Thank you very much.
-mjm
"Thilak" wrote in message
news:ef06b16.0@WebX.SaUCah8kaAW...
> Hi Michael,
> Check this out.
you
you
you
So
how
> to achieve this.
VBA
> Option Explicit
> Sub f_plotWindow()
> Dim p1 As Variant
> Dim p2 As Variant
> 'get two points
acDisplayDCS,
> False)
acDisplayDCS,
> False)
of
> End Sub
> pd_xMin = p2(0)
> p2(0) = p1(0)
> p1(0) = pd_xMin
> End If
> pd_yMax = p2(1)
> p2(1) = p1(1)
> p1(1) = pd_yMax
> End If
> End Sub
> Cheers,
> Thilak
peculiar
> check
> not
fresh
> > -mjm
