Find and locate external references in drawings
sunchuanpu
sunchuanpu
I am using an external reference as frame for printing. Is there any ways to find and locate the external references using vba so I can quickly print multiple drawings?
I know the name of external reference. I will know relative locations of its four corners once if I can locate anything like insertion point. There might be multiple pages to print (an external reference used multiple times) in each drawing file.
Thank you very much.
  • VBA
norman.yuan
You can use code to open each drawing and loop through modelspace/each layout to check if there is an AcadExternalReference object, something like:
Dim ent As AcadEntity
Dim xref As AcadExternalReference
For Each ent In ModelSpace[PaperSpace]
  If TypeOf ent Is AcadExternalReference Then
    Set xref = ent
    '' Then examine its name/position... to decide if this is the target Xref and do things accordingly
Next
Norman Yuan
Drive CAD With Code
sunchuanpu
Many thanks!
