Find and locate external references in drawings
sunchuanpu
sunchuanpu
I am using an external reference as frame for printing. Is there any ways to find and locate the external references using vba so I can quickly print multiple drawings?
I know the name of external reference. I will know relative locations of its four corners once if I can locate anything like insertion point. There might be multiple pages to print (an external reference used multiple times) in each drawing file.
Thank you very much.
norman.yuan
You can use code to open each drawing and loop through modelspace/each layout to check if there is an AcadExternalReference object, something like:
Dim ent As AcadEntity
Dim xref As AcadExternalReference
For Each ent In ModelSpace[PaperSpace]
  If TypeOf ent Is AcadExternalReference Then
    Set xref = ent
    '' Then examine its name/position... to decide if this is the target Xref and do things accordingly
  End If
Next
Norman Yuan
Drive CAD With Code
sunchuanpu
Many thanks!
