Filtered On Screen Selection
I am in the process of learning Visual Basic. In the small routine below I want to select, on screen, all objects desired except paperspace viewports. However, it does not work. Specifically, it says the arguments for "SelectOnScreen" are incorrect. What am I doing wrong?
Sub SelectOS()
Dim ss1 As AcadSelectionSet
Set ss1 = ThisDrawing.SelectionSets.Add("sset")
Dim FilterType(1) As Integer
Dim FilterData(1) As Variant
FilterType(0) = -4
FilterData(0) = "!="
FilterType(1) = 0
FilterData(1) = "PViewport"
ss1.SelectOnScreen FilterType, FilterData
End Sub
Try this instead:
Sub SelectOS()
Dim FilterType(0) As Integer, FilterData(0) As Variant
Set ss1 = ThisDrawing.SelectionSets.Add("sset2")
FilterType(0) = 0: FilterData(0) = "~VIEWPORT"
End Sub
"If you want to be somebody else change your mind"
http://www.acadx.com
http://vbxtender.sourceforge.net
What do you want "!=" for, and group -4, it
works only with (ssget), LISP
Select everything, then remove from your selection
set, all Vport:
    If sset.count > 0
Then
        For Each ent In
sset
            If
TypeName(ent) <> "IAcadPViewPort"
Then
sset.RemoveItems
ent
            End
If
        Next
    End
If
Hope this helps.
I
Sub SelectOS()
  Dim FilterData(1)
As Variant
  FilterType(0) = -4
  FilterData(0) =
  FilterType(1) = 0
  FilterData(1) =
"PViewport"
End
Sub
