Delete Selection Set
Message 1 of 14
I am in the process of learning Visual Basic. A particular routine that I am working on creates a selection set. When I rerun the routine within the same drawing I get an error saying that the "selection set already exists". What is the best way to delete the old selection set?
Will Massie
Sause Brothers
Replies (13)
Message 2 of 14
This is the way that I do it.
Joe
On Error Resume Next
oSS("Inserts").Delete
Set oSS = ThisDrawing.SelectionSets.Add("Inserts")
Message 3 of 14
Thanks to the fine folks at
VBDesign.Net.
This is how I get rid of mine:
size=2>''****************************************************************
Public Function vbdPowerSet(strName
color=#000080>As String
) As AcadSelectionSet
color=#000080>Dim
objSelSet As
AcadSelectionSet
  Dim objSelCol As
AcadSelectionSets
  Set objSelCol =
   For Each
objSelSet In
objSelCol
      If
objSelSet.Name = strName
color=#000080>Then
objSelCol.Item(strName).Delete
Exit For
color=#000080>End If
Next
  Set objSel
color=#000080>Set
= objSelCol.Add(strName)
color=#000080>Set
vbdPowerSet =
objSelSet
End Function
joseguia
Will Massie asked:
:When I rerun the routine within the same drawing I get an error
size=2>
Message 4 of 14
There's no need to loop through every selection set when you can simply
access it by name:
Set ss = ThisDrawing.SelectionSets()
A simple error trap will catch the exception that's thrown if the set
doesn't exist. For the least amount of code required to get the job done,
Joe's approach wins. For the *most* amount of code required to get the job
done, vbdPowerSet gets the blue ribbon.
"If you want to be somebody else change your mind"
http://www.acadx.com
http://vbxtender.sourceforge.net
Message 5 of 14
Hmm this is probably true, but I pop this badboy
into a module and ever since I started VBA i have
yet to worry about error trapping for a SelectionSet.
Why is that. because all my selections sets for every
bit code are called out as:
Set ssetObj = vbdPowerSet("mySelectionSet")
as I heard in an info-mercial once
"Set it and forget it" 🙂
no selectionset worrying-jose
"Frank Oquendo" wrote in message
news:D0CAA8A155E901BDEF33CF07A80E53DF@in.WebX.maYIadrTaRb...
> access it by name:
Message 6 of 14
Jose Guia had this to say:
Convenience is no reason for using sloppy code. Here, let me help:
Public Function CreateSelectionSet(ssName As String) As AcadSelectionSet
ThisDrawing.SelectionSets(ssName).Delete
Set CreateSelectionSet = ThisDrawing.SelectionSets.Add(ssName)
End Function
Message 7 of 14
I cannot think of a good reason why you would do it this way. OK, so you want a function. Here you go . . .
Public Function vbdPowerSet(Name As String, oSS As AcadSelectionSet) As Boolean
With ThisDrawing
.SelectionSets(Name).Delete
Set oSS = .SelectionSets.Add(Name)
End With
If Not oSS Is Nothing Then vbdPowerSet = True
End Function
Public Sub Start()
Dim ss As AcadSelectionSet
If vbdPowerSet("SS", ss) Then
MsgBox "Selection Set created"
Else
MsgBox "Oh no, something when wrong"
End Sub
Does the same thing, much faster.
Joe
Message 8 of 14
Ok, so both you guys are right.
Frank and Joe.
I've only been doing this for about a year
and
found the vbdesign.net function and
have
used it ever since.
either way works.
Message 9 of 14
Randall is right too, it's just that IMHO you do not need to go through all those gyrations that his code does to acheive the same results.
Joe
Message 10 of 14
Absolutely correct on all counts, Joe.
Message 11 of 14
Thanks for both your help, I do believe I will
change my evil ways now that I have seen the light.
it does show to do a weebit faster doing it the
y'alls way.
thanks,
bye
Randall
Joe
Message 12 of 14
I've been having trouble with the code for deleting a selection set
if it exists:
'Delete the Selection Set GlyphIDs if it Exists
If Not IsNull(ThisDrawing.SelectionSets.Item("GlyphIDs")) Then
Set setGlyphIDs = ThisDrawing.SelectionSets.Item("GlyphIDs")
setGlyphIDs.Delete
Doesn't run unless the selection set already exists.
David William Edwards
www.tcfonts.com
Font Services: Creation, Customization & Conversion
Fontasm! Truetype to AutoCAD SHX Font/Arc-Based DXF Converter
Message 13 of 14
Isn't that what the code is designed to do? Even so, try this:
http://code.acadx.com/visualbasic/010.htm
Someone left the grass out in the yard all night
Message 14 of 14
ThisDrawing.SelectionSets("GlyphIDs").Delete
Err.Clear
"David William Edwards" wrote in message news:BD4F1C0FD5FE87C41473185E1B35BEDD@in.WebX.maYIadrTaRb...
> if it exists:
> setGlyphIDs.Delete
> End If
> www.tcfonts.com
