filter by handle
filter by handle
Message 1 of 10
filter by handle
Hello!!
How can i filter in selection set by handle??
i've tried
Dim selecthandle As AcadSelectionSet
Set selecthandle =
ThisDrawing.SelectionSets.Add("selectbyhandle")
Dim intcodes(0) As Integer
Dim varcodevalues(0) As Variant
intcodes(0) = 5 'this supose is the dxf code of handle
varcodevalues(0) = "9A3A" 'this is the entity handle
selecthandle.Select acSelectionSetAll, , , intcodes,
varcodevalues
and it does not work
thanks
Replies (9)
Message 2 of 10
Why not use the ObjecToHandle function?
Dim MyObj as AcadObject
Dim MyHandle as String
MyHandle = "9A3A"
Set MyObj = ThisDrawing.HandleToObject(MyHandle)
Jimmy Lopez wrote:
> Hello!!
> i've tried
> Set selecthandle =
> varcodevalues
> thanks
Message 3 of 10
The object to handle function works great for a single object, but I want to filter for more than one handle and make them part of a selection set!
I would appreciate any help!
Message 4 of 10
SSI,
I'm not sure if this will help but....isn't a handle a Long Data Type? Does changing from string to numeric help?
Bob Coward
CADS, Inc
800-366-0946
bcoward@mindspring.com
Message 5 of 10
Jimmy,
I need to create a selection set using multiple handles. Were you able to get Group Code 5 to work or did you find a work around?
Message 6 of 10
Con,
The example you provided works great, but I need to filter by for multiple handles and make them part of a selection set.
I would appreciate any help you can provide!
Message 7 of 10
Why not create a comma-separated list of handles passing it subsequently to the SelSet filter (DXF code 5 if I'm right?) You can also use wildcards (*) in filters, but not in this specific case. Regards, Maksim Sestic www.geoinova.com "SSI Services, Inc." wrote in message news:20641122.1084984322988.JavaMail.jive@jiveforum1.autodesk.com... > Con, > > The example you provided works great, but I need to filter by for multiple handles and make them part of a selection set. > > I would appreciate any help you can provide! > > Thanks,
Message 8 of 10
I am using VBA! Group Code 5 does not appear to work in VBA! Any other ideas?
Message 9 of 10
Loop through your list of handles and add them individually to the selection set using the SelectionSet.AddItems method. You may need to wrap them into a variant array to be a valid parameter for AddItems. You could using single-cell arrays, one at a time, or put them all into one array and use a single AddItems call -- your choice. I don't really see the advantages of doing this. If you already know which objects you're interested in, and you have to loop through them anyway to use HandleToObject, building a SelectionSet may just be extra work for you and the computer. But, then again, every project has its own quirks and workarounds... Good luck, James
Message 10 of 10
VBA doesn't seem to accept Group Code 5. If you need all your objects in a selection set I would do this:
1. Create a blank selection set
2. Use HandleToObject to get the first object
3. Use the AddItems method of the selection set to add the object
4. Repeat steps 2 & 3 for all remaining handles
Regards - Nathan
