FIllet Two Members Through VBA
I'm using Autocad 2016. During the installation of Autocad, I encountered an unhandled exception c0000005 (access violation reading 0x118b) at address 748206BEh. I was attempt to many way, but cannot fix this error. 2018-11-07.pngNow, what should I do to fix that?
norman.yuan
It is very confusing:
1. You said "I'm using AutoCAD 2016.", which suggests AutoCAD is runnable;
1. the title of your post suggests that you are trying to run VBA code;
2. The picture shows AutoCAD was running BEFORE the error message showed;
3. Yet, you said "During the installation of AutoCAD, I encountered an unhandled exception....", suggesting the AutoCAD installation itself failed. Then how can you use AutoCAD if its installation was not successful?
Norman Yuan
Drive CAD With Code
