Fill listbox with layers
Message 1 of 9
Hello ,
I'm looking for a solution for hours but i can't find
I am looking for a way to fill the listbox with all drawing layers.
Excuse me for my English, this isn't my native language
Replies (8)
Message 2 of 9
Alfred.NESWADBA
what is the question? Filling a listbox in a form or getting all layernames?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 9
Filling a listbox in a form.
My idea is this: When I click on the box, a drop-down menu or a list appears with all the names of the layers present in the drawing. That's why I want to use the box. Then I use the name of the layer chosen by the user to apply my code to this layer.
My probleme is that I can not fill the box, it remains empty.
it does not seem so complicated but I do not succeed. Do you have an idea how to proceed?
thank
Message 4 of 9
Alfred.NESWADBA
There you find how to add items to a listbox >>>click<<<
If you show your code where you are we can discuss your lines and where exactly a conflict exists (might exist).
- alfred -
Alfred NESWADBA
Message 5 of 9
Thank you for this link .
I will look in more detail at the content of the web page and keep you informed of the progress of my problem.  🙂
Message 6 of 9
Yeah !! I have found !! 🙂
Code :
Private Sub UserForm_Initialize()
Dim MyLayer As AcadLayer
Dim NomCalque As String
    For p = 0 To ThisDrawing.Layers.Count - 1
    NomCalque = ThisDrawing.Layers.Item(p).Name
    UserForm1.SelectCalque.AddItem NomCalque
    Next
End Sub
 In order for the listbox to be filled automatically when the UserForm is launched and not when you click on a button, you must place the code in Private Sub "Name of your UserForm"_ and the parameter "Initialize()".
Message 7 of 9
You could simplify your code a little:
For Each MyLayer in ThisDrawing.Layers
UserForm1.SelectCalque.AddItem MyLayer.Name
Next
End Sub
Or optimize it from the memory access point of view:
Dim MyLayers As AcadLayers
Set MyLayers = ThisDrawing.Layers
With UserForm1.SelectCalque
For Each MyLayer in MyLayers
Next
End With
End Sub
Although you should not notice any difference in actual processing time, you could adopt it as a good programming habit
Message 8 of 9
ASE-Rrenteria
I have looked every which way and I have failed to find how to do this in c#. Example exists about adding a layer to a drawing, but it does not help me in filling a Listbox with the layer names of the current drawing. Could any of you guide  me?
Thank you so much.
Message 9 of 9
Ed__Jobe
The process is much different in C#. You should start a new question in the .NET forum. State if you are using a winform or a wpf form.
Ed
How to post your code.
