Extracting attribute information from existing blocks
Can anyone help !
I currently have some code which works fine until other entitys are added
into the drawing.
When executing, a 'Type Mismatch' error is displayed.
Would I be correct in thinking it is something to do with Blocks statement ?
Thanks in advance
Dave
The code is as follows:
Dim SelSetObj As AcadSelectionSet
Dim Num As Integer
'interogate drawing for scale and revsion status
'set up selection set
Set SelSetObj = ThisDrawing.SelectionSets.Add("TEST_SSET")
SelSetObj.Select acSelectionSetAll
Num = SelSetObj.Count
'read block attributes and set to user input
** For Each Blocks In SelSetObj **
If Blocks.EntityName = "AcDbBlockReference" Then
If Blocks.HasAttributes = True Then
Attributes = Blocks.GetAttributes
For I = LBound(Attributes) To UBound(Attributes)
If Attributes(I).TagString = "REV" Then
NewRev = Attributes(I).TextString + 1
Attributes(I).TextString = NewRev
End If
If Attributes(I).TagString = "SCALE" Then
FrameScale = Attributes(I).TextString
End If
Next
End If
End If
Next
blocks should be defined as AcadEntity
Dave Wilkinson wrote in message
news:7ED5632B95005D5A6ABE3D1C9B808C72@in.WebX.SaUCah8kaAW...
> Can anyone help !
> into the drawing.
> Thanks in advance
> Dave
> Dim Num As Integer
> End If
> End If
> Next
> End If
> End If
> Next
Hi Dave
This should do it.
Option Explicit
Sub test()
Dim Num As Integer
Dim Attributes As Variant
Dim Blocks As AcadBlockReference
Dim DXFData(0) As Variant
Dim I As Integer
Dim NewRev, FrameScale As String
DXFCode(0) = 0: DXFData(0) = "INSERT"
SelSetObj.Select acSelectionSetAll, , , DXFCode, DXFData
End If
End If
Next
End If
Next
SelSetObj.Delete
End Sub
Trond Hasse Lie
Norway
"Dave Wilkinson" wrote in message
> Can anyone help !
> into the drawing.
> Thanks in advance
> Dave
> Dim Num As Integer
> End If
> End If
> Next
> End If
> End If
> Next
Dave,
I imagine that you are only changing one or more blocks with the same name.
You can try this code for a more cleaner overview and run.
< snip >
Dim fType(0 To 1) As Integer, fData(0 To 1) As Variant
On Error Resume Next
Set SelSetObj = ThisDrawing.SelectionSets("temp")
If Err Then Set SelSetObj = ThisDrawing.SelectionSets.Add("temp")
SelSetObj.Clear
On Error GoTo 0
fType(0) = 0: fData(0) = "INSERT"
fType(1) = 2: fData(1) = "yourblockname"
SelSetObj.Select acSelectionSetAll, , , fType, fData
If SelSetObj.Count > 0 Then
For i = 0 To SelSetObj.Count - 1
Attributes = SelSetObj.Item(i).GetAttributes
For j = LBound(Attributes) To UBound(Attributes)
Select Case UCase(Attributes(j).TagString)
Case "REV"
NewRev = Attributes(j).TextString + 1
Attributes(j).TextString = NewRev
Case "SCALE"
FrameScale = Attributes(j).TextString
Case Else
End Select
Next
Next
End If
< snip >
If you have more tags in your block, just ad more "Case".
Rene
(and Frank for learning me this trick)
I have tried to define the Blocks as an AcadEntity, to no avail !
I receive the same error message as before, only this time it happens every
time, regardless of what entity's are present.
I have also tried the code below, which works fine. The problem here is that
I not using a single block name, and have the possibility of six different
names for the block.
Can anyone give me any further ideas.
Thanks for your time
Dave
Rene van Kwawegen wrote in message
<235B0BDC410656B11857D9534D5E0CCE@in.WebX.SaUCah8kaAW>...
>Dave,
>< snip >
>SelSetObj.Clear
>On Error GoTo 0
> Case "REV"
> Case "SCALE"
> Case Else
> End Select
> Next
> Next
>End If
>< snip >
>Rene
If you use a selection set filter as both Trond and Rene suggested, your
selection set will contain nothing *but* block references, so there will be
no problem declaring your iterator object as AcadEntity or better yet:
AcadBlockReference. You may want to double-check the code you are using to
create your selection set.
Attitudes are contagious. Is yours worth catching?
http://www.acadx.com
news:8EDD02D65C37A145D59441153C83A735@in.WebX.SaUCah8kaAW...
every
that
Yes Frank, you are quite right.
I had started to look at filters to give me a selection set of just blocks.
Now I have added in a filter, things seem to be working fine.
Thanks to everyone for your time
Dave
Frank Oquendo wrote in message ...
>every
>that
different
