Exploding Text
Exploding Text
greneebb
Message 1 of 10
Exploding Text
greneebb
Good Day.
Is there VBA to explode text?
Replies (9)
Message 2 of 10
Norman_Yuan
No, VBA/COM API does not have a way to explode Text, as the Express Tool's "TextExp" command.
Norman Yuan
Drive CAD With Code
Message 3 of 10
greneebb
Thanks for your response.
This situation existed since 2000. I can't believe that a resolution has not been reached yet.
The problem is that text cannot be sent to a cutting machine, so it has to be broken into lines and curves.
Isn't there a way to do this besides the explode command?
Message 4 of 10
Ed__Jobe
You're using the wrong software. AutoCAD was never designed to send items to any cutting machine. Use a product design software like Inventor or Fusion 360. 3D text is built into the software. And there are add-ons for exporting to cnc machines.
Ed
How to post your code.
Message 5 of 10
greneebb
Thanks for the explanation.
You are correct. However, my intent was incorrectly stated, because AUTO drawings cannot be used directly by cutting machines.
What I really meant was that the drawings are saved in dxf format and sent to another software, like RDCut, which intern sends the images to the cutting machine.
So, what I am looking for is a means of using VBA to break up the text in much the same way that Text Explode in the Express Tools menu works.
At the moment using this command does the job fine. But now I want to automate it using VBA.
Message 6 of 10
Ed__Jobe
Yes, I fully understand what you are trying to do. I'm just saying that these are the wrong tools. There are tools that are specifically designed to do what you want. That said, if you still want to use AutoCAD and dxf. Since you are probably not writing paragraphs of text. For something like this, you probably only need a few letters that will actually be used. I would make up a set of blocks for each letter. Those you can explode. to line the block text up, you could place some dtext and overlay the blocks to match the spacing. If you're ambitious, you could even write a command to place the blocks. Or if you have standard lines of text, make the whole line a block.
Ed
Message 7 of 10
grenee
Observer
Observer
Thanks. This is good food for thought. I would experiment.
Message 8 of 10
lelandarjun12
Community Visitor
Community Visitor
The VBA/COM API lacks a direct method similar to the "TextExp" command found in the Express Tools. I need to achieve the same result as "TextExp" – essentially exploding text elements – but I'm struggling to find a straightforward way to do this through the API. I've searched https://rainguardroofs.com/ through the documentation, but it seems that this specific functionality might not be readily available. If anyone has faced a similar situation or has suggestions on how to work around this limitation, I'd greatly appreciate your insights.
Message 9 of 10
Norman_Yuan
My understanding to your question is that you are doing a VBA/COM app for your specific business operation, in which you need to explode texts. That is, exploding text is part of the coded operation, thus, using SnedCommand() to call "TXTEXP" command of express tool might be problematic because of it being executed asyncly.
If you do AutoCAD .NET API programming, it might be easier to incorporate Express Tool's "TXTEXT" into a coded custom operation because of .NET API's richer event handling mechanism. One of my articles was specifically on how to use "TXTEXP" in a custom coded operation:
https://drive-cad-with-code.blogspot.com/2022/11/loop-operation-with-sendstringtoexecute.html
Norman Yuan
Drive CAD With Code
Message 10 of 10
Ed__Jobe
@lelandarjun12 The TEXTEXP command uses WMFOUT and WMFIN commands to explode the text. You could try that yourself to see if it does what you want.
Ed
